Question about Dell PowerEdge 1600SC Server
NO HARD DISK FOUND DELL POWER EDGE 2950 - Dell PowerEdge 1600SC Server
  • Dell Master
  • 3,866 Answers
Your probably got one ofthe following:
1. har drive crash
2. Hdd controller failure
Ether witch will need replacment parts and that you would see a local tech for if you do not know what your doing. You might need a new hard drive or acontroller in this case.
Thanks and please do be considerate and leave postive feedback ratings.
Posted on Jun 07, 2010
I have a Dell Power Edge 2950 running on Ubuntu. Is there any program that i can run to check my hardware because i had a Error message E1810 HDD disk failure. i remove the disk and put it back on but i...
You may have a damaged hard drive and it needs to be replaced. If the system is still under warranty, Dell will replace the drive free, you just need to go online, supply your systems tag number and follow the instructions from there. If you have just the one drive, you will need to restore the information froma a backup. If you have a RAID set up, once the hard drive is reinstalled, the RAID will sync the drive to the others.
Good Luck
C2Solutions
Oct 14, 2011 | Dell PowerEdge 2950 (becwfk1_6) Server
Dear i am training to inistall suse linux10 sp1 on the DELL power Edge 6850 when the inistallation start there was an erorr that no hard disk found.
(most likely) If your server has any hardware raid devices you may need to locate and configure the linux drivers for that, instruction should be included for linux config.]
Apr 24, 2011 | Dell PowerEdge 6850 (PE6850SAPP) Server
Windows 2008 r2. cannot find SAS HDD during install. I have tried to use drivers from Delll official site. But it doesn't help.
What RAID controller are you using? Also, you must first configure RAID in CTRL-C (SAS 5/6) or CTRL-R (PERC 5/6) before even loading the driver will help.
Mar 18, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
How to install sata hard drive on dell power edge
You have to "FDisk" or "Partition" the Drive before Windows will see it.
XP - Goto: Control Panel | Administrative Tools | Computer Management | Disk Management
Vista/Win7 - Goto: Control Panel | System and Security | Administrative Tools | Computer Management | Disk Management
You will see hopefully both Drives... Highlight the New One... Create a New Partion by Right Clicking or use the Pull Downs. It will ask size etc... use the defaults.
Next Format the Drive - Select the Drive again...Right Click Format using Quick Format to save time and you should be set.
Jan 02, 2010 | Dell PowerEdge 1600...
I have dell power edge 800, the light A,B,C,D don't come up when switching on and hard disk don't power up, please any help ....
Probably your power supply ... try reseating power connectors. If not, then replacement is in order.
Jan 02, 2010 | Dell PowerEdge 1800 Server
Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge 1600SC Server Logo
1,022 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
