Question about Toshiba Satellite A100-S8111TD Notebook
My cam is not compatible to windows7
My problem is about my windows.How can i change it windows7 to window vista because my cam is not compatible to windows7.i
  • Toshiba Master
  • 12,061 Answers
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all. make sure you install and run all.any programs as Administrator.
Posted on Jun 07, 2010
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
Dvd not working in bios or Windows 7
It's a common problem when upgrading a OS? Is the DVD rom the only component that's missing a driver? Any Unknown Devices? Have you opened the Device Manager and looked for the DVD? In Device Manager, Scan For Hardware Changes. Not Listed? Have you done ALL your windows Updates? All the HP updates? Try the driver here: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-58707-1&cc=us&dlc=en&lc=en&os=2093&product=3548266&sw_lang= Download the software and SAVE to a folder. Modify the compatibility of the software from Win 7, using this procedure: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/ BEFORE YOU START, CREATE A RESTORE POINT. With this procedure: http://windows.microsoft.com/en-US/windows7/Create-a-restore-point.
Jan 13, 2013 | HP Pavilion Computers & Internet
I have a quickcam v11.1 with driver windows xp , windows vista from logitech! I want to download a driver for the same quickcam v11.1 for windows7
Its possible that your cam's software/drivers is not supported on windows 7.
First uninstall the installed driver. After uninstalling, right-click on the setup of driver and click on- "Properties". The dialog box will open on which you have to click on "Compatibility" tab.
On that tab, check on the box- "Run this program on compatibility mode for-" and select "Vista" from the drop down box.
This will surely fix your problem.
Please vote this answer if helpful.
Apr 19, 2011 | Computers & Internet
How can i run my DOP on my Windows7 64bit
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and then select the Windows version you know the program worked on before. This way the program will be run as it would run under Windows XP or Vista, 32 bit or 64 bit.
You can find more about this Compatibility issue on http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Feb 01, 2011 | Voyetra Turtle Beach Digital Orchestrator...
HELLO SIR I COULD NOT ABLE TO FIND THE RIGHT DRIVERS aspire 5635
Hi Mr. Waddy I m not sure that the drivers would support Windows seven yet. Available for Vista though. If you have the driver CD you may be able to install it again in a Windows XP environment. There are drivers for vista so either you have to change your cam or Operating System (not a wise idea though since windows 7 is excellent). Drives for Windows versions other than Windows 7 http://download.cnet.com/Acer-OrbiCam-Logitech-zip/3010-18493_4-433982.html?tag=mncol
Please rate the answer if you feel that its helpful. Thanks for contacting Fixya.
May 28, 2010 | Acer Aspire 5100 Notebook
Is de vx 1000 cam goed voor windows7?
I assume you mean if this web cam will work with windows 7 here,if so then you need to check its manual where it mentions it's compatibility criteria.
Dec 15, 2009 | Microsoft LifeCam VX-1000 Webcam
Is dell all in one printer A940 compatible with windows7. I can't seem to make it work.
From the Dell Website... sorry
Dell Printers That Are Not Compatible With Windows 7
Model
Number
Specific Windows 7
Drivers Available
Windows 7 Compatible Drivers
(Use Vista Drivers)
A940
not available
not available
Dec 08, 2009 | Dell A940 All-In-One InkJet Printer
Driver for Windows7
Try running it in compatibility mode
Check out this link
http://tech.nztechie.com/2008/01/install-veo-advanced-webcam-on-windows.html
Nov 06, 2009 | Veo Advanced Connect Webcam
Toshiba Satellite A100-S8111TD Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
