Question about Whirlpool GSX9885J Top Load Washer
Whirlpool Gold Washer GSX9885J E3 & E4 codes
Have a Whirlpool Gold GSX9885J Top Load Washing Machine, purchased in 2001, and it's been working fine until just recently, it worked somewhat okay for a first load, the display screen was not accurate, it would say soak when it was actually draining, etc.
Then the next load had the following error codes E4 E3, with the previous load there were error codes, but they were easily erased by unplugging the machine, now unplugging does not solve the problem.
What do these codes mean?
Thanks
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
canbruce75
  • 1776 Answers
SOURCE: Whirlpool Calypso top loading washing machine
I would check the water inlet valve first. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad solenoid and the inlet valve assy will need replaced. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 07, 2009
  • 311 Answers
SOURCE: Whirlpool Duet 9100 will not drain during regular wash cycle
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Posted on Jan 13, 2010
sclarke7
  • 222 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash2_bing.gif.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Posted on Mar 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Calypso top load washing machine. No warning... no power. no breakers tripped! Outlest tested fine with another appliance.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
I have an e3 and e2 on my whirlpool top loader washer
Hello Jenny ramos! We are terribly sorry to hear of your concern with your Whirlpool Washer. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer id (Jenny ramos), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 17, 2017 | Whirlpool Washing Machines
Will not spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 22, 2011 | Whirlpool GSX9885J Top Load Washer
Washer will not spinn.
Hi.
Please read the solution in the article below:
If you have no spin ...
Regards.
Ginko.
Jan 29, 2011 | Whirlpool GSX9885J Top Load Washer
I have a whirlpool gsx988jq0 and wanted to know it is a belt drive or direct drive,because it spins and stops spinnig and makes a big pounding noise
Hi type washing machine does not unite Pelt
There Kepler
Between the motor and Transemsin and change will find it very easy
D & L in stor
Nov 22, 2010 | Whirlpool GSX9885J Top Load Washer
I have a gold catalyst gsx9885jq0. It has a code reading, F3. It won't do anything.
If I recall correctly, your F3 code has to do with the lid switch. You may need to replace it. Here is a link to the part you need.
http://www.appliancepartspros.com/part_details.aspx?part_id=3020600
Nov 21, 2010 | Whirlpool GSX9885J Top Load Washer
Whirlpool Gold does not spin. No error code.
sounds like the 2 posts are differant. harrison2008 if the coupler is broke it won't agitate.to check it you lean the machine back and look at the motor and gearcase the coupler is right between the 2.you can try turning it by hand with the machine unplugged and it may fall off.
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine makes washing and draining sounds without the pressing power
the switch is most likely shorted..comes from corrosion or simply having water seep into the panel.
Mar 02, 2008 | Whirlpool GSX9885J Top Load Washer
Waher makes weird noise
Click on Whirlpool (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 30, 2007 | Whirlpool GSX9885J Top Load Washer
Changing the outer plastic tub
not a job for the amature, this could lead to other problems.
Oct 04, 2007 | Whirlpool GSX9885J Top Load Washer
Whirlpool GSX9885J Top Load Washer Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
