Question about Refrigerators
Fridge is icing up due to a blocked drain. How do
Fridge is icing up due to a blocked drain. How do i unblock it
  • 4,793 Answers
Clorine bleach in a squeezey bottle.....use like a pressure waher in the drain hole(s)
Posted on Jun 07, 2010
Hello, can you guys please help me locate what the problem is on my fridge? .. Is building ice on the freezer section.. Thx
If it's building ice on the freezer floor it is likely that the defrost condensate drain is blocked. You will need to remove the drawer, shelves, frozen items, rear panel, rear vent and belt the ice there also until you get the drain unblocked and can force hot water through the hole with a turkey baster.
APPLIANCE 911
Leaking Refrigerators
Dec 08, 2015 | Refrigerators
This fridge continually keeps flooding,the drain tube has been cleared but it soon ices up and floods again is it to do with the silver tube position or
It it floods , then drain tube must be partly blocked ! SIMPLES if unblocked , then water will run away.
Mar 13, 2015 | Refrigerators
My side by side fridge freezer is leaking especially at night. Thanks
Wrong setting of thermostat/malfunction of thermostat/drain line blocked by dust or ice cubes.
Keep setting @5degree/ check thermostat is shuts off fridge by turning counter clockwise. If not replace thermostat./Due to over frosting drain line plugged with ice debris or full of dust. Clean the drain line. Helpful?
Feb 01, 2011 | GE Refrigerators
Clogged drain line, water build up inside food compartment
if lucky you can unblock it with a wire coat hanger, just unravel hanger and push down drain hole.
this does not work pull fridge out and u will see the hose running down to the dissapeter, remove it and clean
if you cant see hose at back it is internal and cannot be taken out
find hole above compressor where water comes from and try to unbock from bottom using coat hanger
if blocked with ice at bottom usually means insulation has broken down...new fridge needed
Sep 25, 2010 | Refrigerators
Need assistance. Water leaking out the front of
you have a blocked drain in the freezer,take off the inside back wall of freezer,melt out the ice with hair dryer,now you have to unblock the drain,i use a steamer,they cost around 50 bucks,stick the nozzle into the drain and blast it out,when you think it's cleared out pour hot water in the drain and if water goes down it's clear,
Jan 28, 2010 | Maytag Refrigerators
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Hello help People, Water is dripping very slowly from the back of the fridge ceiling seemingly coming from the drain in the freezer? We cleaned out both the freezer and fridge and allowed for some...
maybe the drain is blocked further along - at the rear of the fridge. Sometimes there is a small bend or elbow in the drainage system that blocks.Check the outlet to see if water is actually coming out at all.
May 04, 2008 | Refrigerators
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
