Question about DeLonghi Dehumidifiers
New Delonghi Dehumidifier,5 gal:When units beeps that bucket is full,what are exact steps to do 1st:empty bucket, then press what button to restart?or does it restart on its own?
It should resart on its own after putting the empty bucket back in. The beep is to let you know that the bucket full and it shuts off the humidifier until the bucket is emptied and put back into the proper position.
Posted on Jun 07, 2010
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
My dehumidifier keeps beeping??????
The water tank is either full or not positioned correctly. Empty the tank and/or make sure it is positioned correctly (should fit perfectly and not bump out from rest of unit).
If you have it connected to the drain directly, your tank may still be filling up unless you have the PUMP button pressed (and PUMP is showing in the LED screen).
Good luck and please rate me.
-mark
May 05, 2011 | DeLonghi DE400 Dehumidifier
Bucket is empty but it is beeping
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Apr 08, 2011 | DeLonghi DE400P Dehumidifier Dehumidifier
Water bucket
If yours has a button/switch to turn on a pump, that will redirect the water to the drain. Sllee
Jun 28, 2008 | DeLonghi DH40P Dehumidifier
CH1 IS SHOWN AS WELL AS THE BUCKET FULL LIGHT
I have a LG model LHD65EBL that first started icing up along the top edge during humid days. After several months of this, it finally stopped working and displayed CH01 with the bucket full indicator flashing.
I took apart the dehumidifier, removed the temperature sensor from the coil and rubbed it between my fingers. I then plugged in the unit and it started right up, confirming either a sensor or other circuit problem related to that sensor. For my model unit, I ordered sensor assembly #6877A30013L from RepairClinic.com for $21.75 + shipping.
When I received the assembly, I measured the new and old sensor with an ohm meter: new sensor = 5.5KOhms, old, defective sensor = 5.34KOhms. I installed the new sensor assembly and the unit is working fine.
Just because the bucket full indicator is flashing along with an error code does not mean there is a problem with the bucket full switch.
Dec 17, 2007 | LG LD65EL Dehumidifier
Dehumidifiers Logo
211 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
