Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Craftsman 16hp Briggs riding mower. Will not stay running. Cleaned carbs, checked filter and gas is flowing freely. Is there a fuel pump or vaccum on it?
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
  • 21 Answers
SOURCE: Vanguard (Briggs) 20 HP V Twin Mower Engine
pull the tank first and inspect. if u still find nothing, you might want to check your coil
Posted on Aug 22, 2009
bargainbin2
  • 123 Answers
SOURCE: My steem pressure washer has a twin overhead cam
If the gas is higher that the carb it will not have a fuel pump. Have you unhooked the fuel at the carb to see if fuel is getting to the carb? If it is not you have a blockage in the tank or fuel line or a clogged filter. If fuel is reaching the carb you have a stuck needle.
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: Describe your Briggs & Stratton
check fuel flow from the tank out of the fuel fuel pipe allso check the float level sounds like its running out of fuel then its needing fuel .at idle it can get some fuel but at fast no fuel try that mate
Posted on Sep 02, 2009
  • 25 Answers
SOURCE: I have a 22 hp
running rich will make it run colder.....I wouldn't run it anymore til you find theproblem, it will burn your valves. air leak in your intake/carb is more than likely your problem , check for cracks in the intake manifold , leaking gaskets
Posted on Feb 26, 2011
5216 simplicity riding mower has gas going in with the oil
the needle and seat in the carb needs replaced. or if it has a vaccum operated fuel pump, the diaphragm may have a hole in it causing the gas to enter thru the pulse hose.take your air filter out and check to see if theres fuel puddling down inside the carb
Sep 30, 2014 | Simplicity "Coronet 30"" Briggs And...
I have a JD riding mower w/ 17hp Briggs-Stratton that has been sitting 2-3 yrs. It was running fine when it was parked. Obviously the gas was bad. I cleaned tank and filter, verified fuel pump working. ...
did u clean main jet in carb with a tip cleaner running it all the way threw the jet? if so check the needel and set.hook fuel line up and with a drain pan under the carb turn gas on make sure gas is flowing threw the set. if not remove and clean.
Aug 20, 2013 | Garden
16hp v-twin ohv vanguard
it seem like your gas line is sucking some were
Jun 25, 2013 | Craftsman Garden
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Cleaned gas and changed fuel filter. Mower only
There are a number of things that can cause this, depending on the engine fitted. Assuming a Briggs & Stratton V-twin...
Check that the carb solenoid under the float bowl is connected, has battery voltage when the ignition switch is at 'RUN', and is functional.
As a quick check, with the engne OFF, turn key to 'RUN' there should be an audiable 'click' from the carb if the solenoid is working.
After that, check that the fuel pump is delivering fuel (disconnect output, and crank engine). SHould be a good flow.
Oct 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Sears 42" deck mower. It keeps stalling. Sometimes uphill but also on level ground. Gas in filter is present yet just shuts down. What could this problem be?
Most likely this is a fuel pump problem or a float problem in the carburetor. Most carburetors can be cleaned and rebuild but most owners will not
have the proper equipment to do a thorough job. Take it to a good
servicing dealer for his advice and estimate. Sometimes there is a
gasket or a valve problem and a good experience mechanic can
tell a lot by just listening to the engine for a few seconds.
Sep 13, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
you need to rebuild carb and check groverner spring
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
327 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
