Question about D-Link DIR-300 Wireless Router
The internet will cut out after short periods of time
The computer that is accessing the router in another room will stop working after short periods of time, ive reset the router to factory default settings by using the reset button on the back but it still hasnt helped, any advice would be greatly appreciated :)
    President:
  • 548 Answers
Try changing the Ac adapter for the router and after changing it do a reset.
It should work perfectly
Posted on Jun 07, 2010
My toshiba notebook with part number pslu0u-02u002 there's a problem the connection on wifi. Sometimes it can't connect to the router even there's a signal of internet because my room mate his computer it...
remove wireless driver and remove the wireless card, power on , shut down, plug the wifi card and install driver, press the wifi on off short cut key or switch when you need to go internet
Sep 28, 2017 | Toshiba Satellite L505ES5015 NoteBook
Loses connection w. remote computer I have a laptop one room away. The laptop accesses the internet and printers from this location. Most of the time it works. However, it will suddently lose the conection...
Check if this router is stronng enough interms of it signals. Check on the laptop the signal strength of the conenction.
If the signal strength is poor you can either move closer to the wireless router or vice versa or can get an access poitn to boost the signal.
Please rate if helpful.
Thanks
Apr 09, 2010 | NetGear WGR614 Router
Wireless internet will only work when computer is in the same room as the wireless router.
it works like that cos the signal is not reaching other places in your house . Either get the router to a position that has a good line of sight with the other rooms or get an access point.
Hope this helps
Thanks Ranjit
Oct 06, 2009 | D-Link DIR-615 Wireless Router
Problems with internet connection linksys wireless WRT54GS
hello i'd change it to belkin router good luck
shaun
Aug 24, 2009 | Computers & Internet
WLAN USB Adapter Working; WLAN Wireless Router Not Working
The router could be crapping out on you. Hit the reset button and see if that solves the problem. If that don't work uninstall then reinstall the system. If the problem remains contact your internet provider to see if it is on their end. If all else fails buy a new wireless system!
Jun 16, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Netgear wireless only works some of the time at the remote locati
I have seen this many times before, and its either the driver or the wireless card itself.
If its the driver, try to delete the driver and then reeboot, your OS will install it again and you then have to set it up for your Router again, if the problem is still the same, you have to turn it upside down and get a new wireless card(its reasenble easy to change).
/Teis
If this helped, do vote :-)
Nov 23, 2008 | NetGear WGR614 Router
Acer internet problems
I am also having problemas..I have an acer computer....sometimes my internet comes on and sometimes it doesen't, but it tells me that I am connected!! What do I do?
Oct 20, 2007 | Computers & Internet
D-Link DIR-300 Wireless Router Logo
108 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
