Question about Sharp Televison & Video
Sharp LCD Aquos will not turn on.
My Sharp 52' inch LCD Aquos television will not turn on. When I try to turn it on the "power" light and the "opc" light flash together and have a clicking noise as if it is going to turn on. When it does not turn on, the lights keep flashing together and then the "power" light will flash by itself. I have took the back off to see if I could hear where the noise is coming from so I can get the part to fix it. I have went to Fry's, Conn's and Best Buy, and none of the electronic stores carry the model that I own. I loved the television when it showed, and I would rather attempt to fix it as opposed to purchasing a new television. Could someone please tell me if you are aware of a possible solution? Thank you in advanced for your response. :)
    Top Expert:
  • Sharp Master
  • 41,839 Answers
The power supply may have failed
Posted on Mar 23, 2017
SOURCE: Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Posted on Sep 20, 2009
SOURCE: sharp Aquos will not power on. OPC flashes green
I had it picked up to be fixed on warranty. Downside is I'm out a TV for a week.
Posted on Nov 23, 2009
  • 8457 Answers
SOURCE: no picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Posted on Dec 28, 2009
Zenodilodon
  • 145 Answers
SOURCE: 52 sharp aquos tv wont turn on. Hear click of tv
This tends to be the result of an electrolytic capacitor somewhere, either on the main board or the power supply board bursting due to overheating. In this case you can pull off the back paneling and review the boards over to make sure all the capacitors are in excellent condition. After identifying a bad capacitor you can buy one from an electronics store in the area or a reputable online source. To replace it this will require soldering. Look for a capacitor with the same uF, the voltage can be the same or higher. Make sure all the power is out of the system before servicing, also make sure to note capacitor polarity observing the negative indicator line on the side. If your not sure this can be done at home I would recommend taking it in to a servicing shop. If you do not know what a capacitor looks like do a google image seatch for both examples of a good and bad copacitor. I honestly hope it's something much simpler, I hope this helped and good luck.
Posted on Mar 03, 2010
sodeep
  • 3267 Answers
SOURCE: sharp aquos 32" lcd. power and opc flash once,
replace input board
Posted on Jun 28, 2011
Sharp Aquos tv
If you wiah to get some details about flat panel television repair then check the following link.
http://electro-medical.blogspot.com/
Sep 21, 2016 | Sharp AQUOS 52" Flat-Panel LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Switching of opc and power light when tv is turned on but no picture
Use a flashlight 2 inches away from screen to see if you see a picture, if so then it's your inverter boards that needs repair or replacing. If no picture then power supply board may have bad caps
Dec 23, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Jan 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No picture no sound opc light and power light
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
We cant turn on the Sharp Aquos TV and the power and opc buttons are flashing.
Ur power light stable green first turn on?Then awhile click,POWER and OPC flashes.Tries on/off couple time,will work.Not then ur backlight video board is dead.
Dec 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
334 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
