Question about Conexant Cnet 5614RV V.92 56K Internal Software PCI Modem w/ chipset (MODCN5603)
Alarm going off ....ding..ding,,,ding....
HELLO OVER THERE...ACROSS THE POND I SIT HERE IN HOLLAND OHIO
USATHE OTHER SIDE OF THE POND...NOW THANKS FOR THE HELP TO DATE ...BUT...AND THERE IS ALWAYS A "BUT "I THINK I STUMBLED AND I MEAN STUMBLEDUPON THE PROBLEM AND THOUGHT I WOULD ASK YOUR ADVICE AND INPUT IN THEHOPES THAT YOU ALL COULD / WOULD ADD THIS INFO TO YOUR TICKLER FILE FORTHE FUTURE "STUMBLERS.
WELL HERE IS THE REST OF THE STORY...I JUSTPURCHASED THIS UNIT ON E BAY FROM SOME ONE WHO I HAVE PURCHASED 3OTHERS IN THE PAST..THIS COMPUTER AS THE OTHERS DID NOT COME WITH A 56K MODEM SO I USE THE DYNEX 300M EXTERNAL UNIT AND HAVE BEEN VERYHARPY WITH THE PRODUCT SO I BOUGHT 2 MORE ON E BAY SO I HAVE A TOTAL OF3 MODEMS ....NOW HERE IS WHAT HAS BEEN HAPPENING ON ONE COMPUTER THEDYNEX WORKS FINE BUT NONE OF THE MODEMS WORK ON THE IBM PROPERLY THEYMUST BE RE-SET WHEN THE COMPUTER IS TURNED ON SO THEY THEN CONNECT METO THE INTERNET NOW WE GET TO THE "GUTS OF IT ...I TOOK THE MODEM FROMTHE COMPUTER THAT WORKED PROPERLY .....AND I ALSO TOOK THE USB HOOKUPCORD..."WHOLA" PROBLEM SOLVED...IT WORKED WITH ALL THE MODEMS IT WASTHE THE HOOKUP USB WIRE ALLTHE TIME '''WATSON"........I THEN NOTEDTHAT THE OTHER 2 WIRE THAT I WAS USING WITH THE MODEM WERE THINNER THENTHE ONE THAT I USED WITH THE MODEM THAT WORKED PROPERLY...SO YOU SEE IHAD THE WRONG USB WIRE THAT CAUSED THE PROBLEM "I DO BELIEVE "
INYOUR OPINION COULD THIS HAVE CAUSED THE PROBLEM WITH THE ALARM???? IFYOU ANSWER YES THEN I WISH TO APPLY FOR A JOB AT YOUR FIRM AND MAKE THEBIG BUCKS LIKE YOU ALL DO.WELL THANKS FOR THE HELP YOU GAVE WHAT YOUDID IS MAKE AN OLD RETIRED PUT HIS BRAIN BACK TO WORK.
THANKS AGAIN
RALPH oo7
my hat's off to the team accross the pond
USA THE OTHER SIDE OF THE POND...NOW THANKS FOR THE HELP TO DATE ...BUT ...AND THERE IS ALWAYS A "BUT "I THINK I STUMBLED AND I MEAN STUMBLED UPON THE PROBLEM AND THOUGHT I WOULD ASK YOUR ADVICE AND INPUT IN THE HOPES THAT YOU ALL COULD / WOULD ADD THIS INFO TO YOUR TICKLER FILE FOR THE FUTURE "STUMBLERS.
WELL HERE IS THE REST OF THE STORY...I JUST PURCHASED THIS UNIT ON E BAY FROM SOME ONE WHO I HAVE PURCHASED 3 OTHERS IN THE PAST..THIS COMPUTER AS THE OTHERS DID NOT COME WITH A 56 K MODEM SO I USE THE DYNEX 300M EXTERNAL UNIT AND HAVE BEEN VERY HARPY WITH THE PRODUCT SO I BOUGHT 2 MORE ON E BAY SO I HAVE A TOTAL OF 3 MODEMS ....NOW HERE IS WHAT HAS BEEN HAPPENING ON ONE COMPUTER THE DYNEX WORKS FINE BUT NONE OF THE MODEMS WORK ON THE IBM PROPERLY THEY MUST BE RE-SET WHEN THE COMPUTER IS TURNED ON SO THEY THEN CONNECT ME TO THE INTERNET NOW WE GET TO THE "GUTS OF IT ...I TOOK THE MODEM FROM THE COMPUTER THAT WORKED PROPERLY .....AND I ALSO TOOK THE USB HOOKUP CORD..."WHOLA" PROBLEM SOLVED...IT WORKED WITH ALL THE MODEMS IT WAS THE THE HOOKUP USB WIRE ALLTHE TIME '''WATSON"........I THEN NOTED THAT THE OTHER 2 WIRE THAT I WAS USING WITH THE MODEM WERE THINNER THEN THE ONE THAT I USED WITH THE MODEM THAT WORKED PROPERLY...SO YOU SEE I HAD THE WRONG USB WIRE THAT CAUSED THE PROBLEM "I DO BELIEVE "
IN YOUR OPINION COULD THIS HAVE CAUSED THE PROBLEM WITHTHE ALARM???? IF YOU ANSWER YES THEN I WISH TO APPLY FOR A JOB AT YOUR FIRM AND MAKE THE BIG BUCKS LIKE YOU ALL DO.WELL THANKS FOR THE HELP YOU GAVE WHAT YOU DID IS MAKE AN OLD RETIRED PUT HIS BRAIN BACK TO WORK.
THANKS AGAIN
RALPH oo7
"FixYa.com" <auto-gen@fixya.com> wrote: alarm going off ....ding..ding,,,ding.... - fxnlogo_s.png Technical Support, Instructions & Repair Service
Dear RALPH oo7,
Posted on Apr 11, 2008
The alarm dings. Why does the ice/water dispenser then shut off and lock?
Not sure if I'm reading this right. Is the alarm you are talking about the one that tells you the door is not closed all the way??? If that is correct, then the reason your ice/water system is not working is because the wiring system for the dispenser is fed through a switch on the freezer door which keeps the dispenser off when the door is opened. You need to correct the door problem causing the alarm to ding and that should also fix the dispenser problem. Possibly a door adjustment needed. Door top edges should be aligned and even across the top and the gap between the doors should also be the same distance top to bottom if this is a side x side.
Mar 21, 2015 | GE Refrigerators
Trunk ajar light comes on while driving. and panic alarm goes off by its self
You have bad connections/switches all over the place. i would go over all of them with chemical cleaners and also work the heck out of all switches to make sure they open and close properly. You do this correctly and you will have eliminated all false alarms
Sep 12, 2017 | 2006 Pontiac Grand Prix
New refrig from lowes one week old. now makes ding ding ding ding ding noise 5 times? looked in manual no help
Hell Bill, I am happy to assist you! Sounds like you are referring to the temperature alarm. When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis or the manufacturer directly.
Aug 01, 2013 | Frigidaire Refrigerators
I have a 200 ford taurus and the alarm lite keeps beeping all the time what can i do
I've been jiggling the key switch almost every time I park my Aerostar to get it to quit dinging. I should replace the key switch.VERY easy to do. don-ohio
Jan 12, 2012 | 2000 Ford Taurus
"1999 Buick Century" unknown dinging draining
It's probably your ignition not being exactly disconnected when you remove the key.Until you get a new ignition (keyswitch),just jiggle the switch with your fingers after you remove the ke7y and see if the dinging stops. my Aerostar has that problem right now. don-ohio
Oct 12, 2011 | 1999 Buick Century
Is there any way to shut the door alarm off?, my wife can't stand it. Thanks!
If it doesn't have a button to turn off the alarm on the front panel, there is nothing that can be done.
Aug 03, 2011 | LG LSC26905TT Side by Side Refrigerator
I have a 2003 Chrysler Town & Country and I just changed the battery. It now dings when the door is open with the lights off and keys out of the ignition. Whats wrong?
Changing the battery is probably just coincidence to the key warning.
The key warning alarm (ding, ding ding sound) is supposed to only happen when the key is left in the ignition and th e door is opened; to remind you to take the keys out.
However, over the passage of time, dirt can articulate in the key way and cause the warning switch inside to stick and cause the alarm.
Try this:
  • With key out, tap or rap on the steering column with your hand. This might jar the switch loose (This is commonly referred to as "get a hammer" method-joking)
  • Try spraying some silicone lubricant into the key way and working the key back and forth to see if this clears the switch.
Please post a comment here to let me know if this worked, ok. Thanks J
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Feb 15, 2011 | Chrysler Town & Country Cars & Trucks
Need to know what you call the plastic bulb side of pressure tank
this is a water systems pump. Made now by Franklin Pump Systems in Ohio.
Dec 31, 2008 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Door alarm continually dings
This model and the Kenmore equivalent still have lots of bugs... I've replaced the microprocessor board on mine twice -- thankfully under warranty -- costs in excess of $600,,,
my suggestions are:  1)  verify that the two door switches (at top seal area one each side) appear to be working OK -- push them w/ your finger and see if the the refrigerator light goes off  2)  either pull the plug on the refrigerator or open the breaker feeding it -- count 30 seconds and put power back to it -- it's a computer, every so often you have to "reboot" it because it it loses its mind now and then...  3)  you should be able to push (I think the left most touch pad) the touch pad key under the alarm to shut it off....  4) if all else fails, ??? can you afford not to replace it ???
Jul 27, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Conexant Cnet 5614RV V.92 56K Internal Software PCI Modem w/ chipset (MODCN5603) Logo
121 people viewed this question
Top Conexant Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jessi Singh
Level 1 Expert
Are you a Conexant Computer and Internet Expert? Answer questions, earn points and help others
