HP Compaq Presario 2200 Notebook Logo
Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tones with 1 and follow by 3 - HP Compaq Presario 2200 Notebook
Anonymous
Level 2:
New Friend:
  • Expert 94 Answers
  • Posted on Jun 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
94
Questions
0
Helped
21649
Points
186
If you are talking about Beep codes then 1 long and 3 short beep codes means there is problem with the graphics card.
Best option contact HP
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
2helpful
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
How a change my rigtone for my text messages?
To change the tone for text messages please follow the steps:-
1) Go to Profile.
2) Select Advance.
3) Press the menu key.
4) Select Edit.
5) Scroll down and select Messages.
6) Select Out of Holster, and change the tone you will hear the tone when you will get the messages.
Do you know the tone spacing for a std 2 tone minitor 3 is it 1 sec for first tone and 3 sec for the second tone with 0 sec. tone interval, and is there a long tone delay
yes it's 1 & 3 with no delay you can use a 5 sec. for
a group tone,[i.e.] use the last tone for the 5 sec.
maybe this will help
4helpful
2answers
Nokia 6300 china mobile phone
To use the MP3 as your message tone, please follow the steps below:
1. Go to Settings and then click Tones.
2. Highlight the message alert tone line and press "Change".
3. Select "Open Gallery" then locate the folder where the MP3s are saved.
4. Select the song the you would like to use as message tone. Click Save.
N3230 tones not recognized
for this problem you are to follow some steps
step 1: switch your handset
step 2: press and hold 3 buttons as
          1 : calling green coloured button
          2 : star button
          3 : three no. key
step 3: swutch on your handset untill there is a messege that            complete formatting
step 4: now your handset has become ok
May 15, 2008 • Nokia 3230
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
