Question about Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Error #803
I have the Kodak Easy Share Digital Camera Z612. When I turn the camera on, I get a blue screen with the error message #803, and the mode dial light blinks. I use the Easy Share Dock to keep the battery charged. I have used it for 2 years with no problems. Has anyone else had this problem?Thanks....
  • 1 more comment
  • conchi Apr 22, 2008
    error #803 en kodak easyshare cx7330 no se lo que quiere decir y la camara o funciona
  • Anonymous Dec 30, 2008
    Same problem here...Camera turned on, blue screen with Error code 803, lens remains out and nothing changes with pushing all of the buttons, except the blue screen will turn on and off.
  • Anonymous Apr 09, 2009
    The camera does not turn on. You get a blue scree with "error #803."
    President:
  • 2,761 Answers
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
My kodak Easy Share Zoom Digital Camera Z612 will not format all the SD cards I buy..the last one I tried was SDHC 4GB. Why not? the SD card that came with the camera is 1.0 GB Digital Media Secure...
The Z612 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to stay with SD cards, 2GB and smaller.
Dec 20, 2010 | Kodak EasyShare Z612 Digital Camera
What memory card would accept my Kodak Easy Share Z612? Thanks!
According to the manual, the Z612 uses MMC and SD cards.
Be careful not to try SDHC cards. They look similar to SD cards and will fit into the slot but are electronically incompatible. SD cards max out at 2GB in size.
Oct 13, 2010 | Kodak EasyShare Z612 Digital Camera
How do you erase the internal memory on a kodak easy share Z612
Press the Review button. Press the Delete button. Follow the screen prompts. "ALL" deletes all images from the current storage location.
Jul 11, 2010 | Kodak EasyShare Z612 Digital Camera
How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
Jun 14, 2010 | Kodak EasyShare Z612 Digital Camera
Easyshare Z612 with an error code of #e45
Itøs a lends error. There is not much else to do than to send it in for repair or go for a trade up.
OoW repair for this model w. this fault: 88,07 Pounds.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 14, 2009 | Kodak EasyShare One Digital Camera
SD HD card won't format
This camera only works with standard SD cards with a max of 2 GB
Mar 31, 2009 | Kodak EasyShare Z612 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
442 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
