Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Cant Acces LOcal host network page
I cant acces local host network pae ... because it always say connection is limited
    Genius:
  • 1,354 Answers
Hi
your netwok is not conacting with your local host
you have to give locale IP in ( TCP/IP)
Clicl on on your Network Icone on the desktop open properties
there will be TCP/IP option there you hve to give locle IP
Posted on Jun 07, 2010
I have acer laptop 5580. 3 year old. Recently i have installed Windows 7. Wireless was working nice. Now, system is identifying the wireless, but not connecting. After troubleshooting it is giving...
If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
May 09, 2011 | Acer (BCM94318MPG) Wireless Adapter
Hi, I bought a TP-Link TL-WA701ND (Wireless Lite N Access Point) today, and am having troubles getting it to work. The Quick Installation Quide gives directions for Windows operating systems XP and Vista...
You must setup manually your acces point. First go to control panel, under network and internet you'll find a task, view network status and tasks click on it and in next page go to change adapter settings, find local area connection and right click on it and go to properties, in next window highlight internet protocol tcp/ip then click on properties in next window click on use the folowing ip adress and write in ip adress box an ip from 192.168.1.2 to 192.168.1.253 at your choice in subnet mask box just leave 255.255.255.0 (this apear when you click in these box). Now connect your acces point to the computer via network cable. Then open your internet browser and type in adress box http://192.168.1.254 and hit enter, a pop up will apear and ask for user name and password, write admin in both boxes user and password and hit enter, after that you will be able to manually configure your acces point and setup a name and password for your wireless network, change your user and password for acces your device. Good luck!
Mar 23, 2011 | ASI TPL WL TLWA701ND 150Mbps AP Wireless...
What is a wireless network connection network key also called a wep or wpa key. Or where can i find it?
Both are security protocol which enable the owner of an wireless network to limit the acces to that network and to protect the data that runs through that network.
WEP stands for WIRED EQUIVALENT PRIVACY and it' a security algorithm designed for wireless networks with the intention to provide a level of confidentiality close to the wired networks
WPA stands for Wi-Fi Protected Access and it's a security protocol designed to secure wireless networks
If your wireless device discovered a network that require such keys,that means that the owner of
that network secured his network,only people having acces are those who know the key.
If you have a Wi-Fi router and you forgot the key ,you have to acces the configuration page of the router ,go to wireless security page and reconfigure it, by changing the key.(get the manual of the router and follow the steps)
Feb 19, 2011 | Computers & Internet
I cant acces my facebook always dns can u please help me acces my facebook
Facebook is down - server problems: http://mashable.com/2010/09/23/facebook-down-again/
Sep 23, 2010 | Facebook Social Network
I cant get acces to my Modem or Wifi using "192.168.0.1? Help
May be 192.168.0.1 is not the address to configure that router.
Start, Run, CMD to open a command prompt:
Type the following command:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
example results.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adamprince>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Adamprinces
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-0A-48-08-24-52
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 202.27.184.3
Lease Obtained. . . . . . . . . . : Tuesday, 24 August 2010 5:35:33 p.m.
Lease Expires . . . . . . . . . . : Wednesday, 25 August 2010 5:35:33 p.m.
____________________________________________________
The address to configure that router is 192.168.1.254
Aug 26, 2010 | Computers & Internet
Belkin54g default gateway problems and connecting to router page
reset your Router via pin whole at its back then set the config of TCP/4 and obtain Ip automaticaly and obtain DNS automaticaly... later set your settings according by 192.168.1.2 without changing IP and then turn off you router ... turn it on after 5 to 10 min .. thank you
Jun 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Generic Host Process for Win32 Services encountered
your probably infected with virus. get a good antivirus like kaspersky and then download combofix and scan with it. see if that helps your problem.
Nov 24, 2008 | Intel Motherboard
Can not connect to internet
what connection you use? a dial up or broadband acces?
if u use a broadband acces (maybe from office) u need to fill in gateway and preffered dns that your office use.( u can see the number from another computer)
You can find the setting in : control panel--->Networks Connection--->Local Area Network
- Right click on Local Area Network, choose 'Properties' ----> Internet Protocols(TCP/IP)
Thanks
Nov 06, 2008 | HP Pavilion dv6000z Notebook
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
88 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
