Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
I want to connect to my PowerBook G4. Have the unit. Where is my firewire port?
  • 71 Answers
On your Behringer Sound Sytem, the firewire port is at the back, the firewire ports are actually labeled. On the PowerBook G4, it is usually located right next to the ethernet port and it has like the Y symbol above it.
Posted on Jun 07, 2010
Cant find the disc on my powerbook g4
STart up your G4 using the OS disc for leopard, but instead of reinstalling the system, go to the menu at the top of the screen and Launch Disk Utility.
You may need to remount your hard drive. The disk utitliy can do this for you. Then it should appear in the disk utillity window. Then you should be able to install the OS and away you go!
May 10, 2010 | Apple PowerBook G4 Mac Notebook
Mac External Connection
Easy, FireWire.
Connect the 2 with a firewire cable. If reading off the laptop, for example, reboot it & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The laptop should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Connecting another Mac to a laptop
Connect the 2 with a firewire cable. Reboot the Mac you want to read from & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The other Mac should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Camcorder importing - no manual
This is the same unit I have. Simply connect a 4-pin to 4-pin Firewire cable between the computer and the camera. (Port is under the lens, under a smal rubber cap. Once the connection is made, turn on the camera, and it should appear on your mac as a new fixed drive. Import your files normally from there.
Hope this helps!
Jan 05, 2009 | Canon MV600 Mini DV Digital Camcorder
WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link: http://www.wdc.com/en/products/accessories.asp?ProdID=170
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Oct 21, 2008 | Western Digital Passport WDXML800UE...
Apple Powerbook G4 17in 1.33Ghz. Tiger OS. Airport problem.
I had a similar problem with my 15" 1.33GHz powerbook G4.
My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location.
it's underneath the battery pack.
1. power off your G4
2. remove battery pack
3. there is a latch on the right side (if the charger port is facing down), open it
4. pull back plastic cover tab and gently remove the antenna plug from the airport.
5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self.
6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook
7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch.
8. place battery back into your G4
9. plug computer in, turn on and it should work
if not then there is something wrong with the airport card reader, which i don't think it's the case here..
Jan 12, 2008 | Computers & Internet
Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISPLAYS. Select that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Dec 10, 2007 | Apple PowerBook G4 Mac Notebook
Firewire. USB2
Either or is my understanding- the scanner will accept either. I can see no need for both.
Sep 01, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
65 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
