Question about Asko 24 in. D3350 Dishwasher
Hi,\r\n Hi, We are getting an "F4" error appear on our D3350 whenever we try to use it, (wash, rinse, etc). I can see water coming in from the side inlet, but the error seems to appear once it reaches the inlet for the sprayers. Perhaps the sprayer pipe is blocked? Is there anything that we can do to fix this ourselves? Thanks very much, most appreciated
    Sergeant:
  • 351 Answers
Yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Posted on Jun 17, 2010
  • gunnar_n Sep 05, 2010
    thank you greendude :-) your solution fixed the problem
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
Hi I have an Asko D3350, and have an 'F7' problem, can anyone help. Starts all wash programs then stops half way through with f7 showing. but the pump and discharge hose is clear. If it means anything it...
At the bottom of the dish washer where the water drains from there is a rectangular hole at the back (you will need to remove all the baskets and the screen). Grease can accumulate here and block the tube that feeds a pressure switch, causing this malfunction. This grease will not be visible as it sits under a lip on the other side of the rectangular hole and above it. This would need to be removed carefully as one doesn't want to push the grease into this tube
Feb 02, 2011 | Asko 24 in. D3350 Dishwasher
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
Dec 31, 2010 | Asko Dishwashers
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Dec 30, 2010 | Asko 24 in. D3350 Dishwasher
Whirlpool Dishwasher machine (Mod. ADG 8970/1) wont start. Water is taken in. After several attempts to start an error code "F4" appeared.
Hello Sir,
This error code, " F4 " comes only when the waste outlet is totally clogged with waste and blocked. Try to dismantle the machine and locate the Waste outlet pipe and thoroughly clean it. This will reset the error which is caused.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Whirlpool WFW8300SW
D3350 F4 indicator
F4 This is a Fault with the water fill
Note: Lights blinking, pump running and controls dead indicates an over fill fault
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find that it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. The drain hose must run up to the top of the underside of the counter top then down to the drain. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Aug 05, 2009 | Asko Dishwashers
No water circulation
i had a call on this the other day and the problem was the water valve under the sink was not open all the way. so even though the water valve was energized properly the customer never got the volume the circulation pump needed to wash correctly
Nov 23, 2008 | Asko 24 in. D3350 Dishwasher
My Asko D3330 dishwasher won't load water
Since your dishwasher is under warranty you should contact to the appropriate factory service center for repair your problem !!!!!
Aug 28, 2007 | Asko 24 in. D3350 Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
822 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
