Question about Toshiba 43HX70 43" Rear Projection Television
TV turns off and power light blinks
My Toshiba 43H70 will turn on for about 30 seconds, then click off. The power light will then blink slowly. About 2 seconds off 2 seconds on etc. It will then not turn on any more until I unplug the TV and wait about 20 minutes to plug it back in. It then repeats the same thing...
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Clicking sound can be from a bad capacitor on the power supply board. To start with open the back of the unit and check the power supply board for any blown capacitors. Also check the flyback as it can be some loose wires in the coil. Usually this happens when there is a vibration in the horizontal circuit, the flyback and/or coil can make this noise. Also inspect the fuse if they are working fine and please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Opening the unit is only recommended if you have some electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 07, 2010
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
TV turns off by itself after being on for 60 seconds
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Jan 13, 2008 | Toshiba CN36X81 TV
62inch phillips bigscreen tv
how many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Dec 07, 2007 | Toshiba 43H70 43" Rear Projection...
43H70 has sound by no picture
also check the horizontal o/p transistor for short if ok ,look on the deflection board and see if there are any b+ voltage markings and test with meter for b+.
Sep 12, 2007 | Toshiba 43H70 43" Rear Projection...
43H70 has sound, no picture.
look in by your convergence ic's for load resistors to feed b+ to the ic;s see if any are opened there usually about 2,2 ohms 2watt
No Picture
child lock- make sure its not on....
Aug 08, 2007 | Toshiba 43H70 43" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba 43HX70 43" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
