By Chandler - usenet poster
the hum which is caused by using either the optical or coaxial connection is
a know problem. that KLH customer service knows which may be reached at
877-799-0863. they state that in a month call back to find out if it is
fixed. I suspect that the whole unit may need to be replaced once they
discover, and fix the problem. I believe that a components is not propley
shielded, or grounded and the is what causes the sound.
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 10, 2008
Yes my receiver only hums when I try to listen to the TV that is connect using an optical cable. I've tried different cables, still get annoying humming sound.
Best Solution
posted on Aug 10, 2005
Bray - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Thanks! That appears to be the answer to my problem that I posted earlier.
Regards,
Mike
Regards,
Mike
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for KLH R5100 5.1 Channels Receiver
Email this problem
Email this problem
Can you Help with these Receivers problems?
connect R5100 to DVR/Monitor
I use a Time Warner cable... Answer This...
coaxial audio cable
coaxial audio cable
trying to hook up to this from... Answer This...
Repair Service
Find Receiver Repairman Near You:
