Question about NeoWave PC Audio Graphic Equalizer External Sound System
I accidentally deleted my modem driver in control panel..i need the driver pls.. tnx pls hlp
I hav airtel modem my model number is MMX610U my IME number is 353474020460697 pls hlp for unlocking i want to use that modem with the another sim connection..pls hlp me
what u will have to do is this.insert your device with other carrier.then instantly your software displays a window asking for unlock code and 10 tries remaining.
and now you have to just paste this code there 33929975instantly your modem will be unlocked and now you can use any carrier
NB : your will have to provide the internet settings manually.
any queries are welcomed to rasi5050@gmail.comthis works 100%
Oct 12, 2011 | Zoom 3G Unlocked Usb Modem For Gsm Hspa...
I cannot copy the pics from my cybershot dsc h20 to my laptop. the pics are not visible in the laptop. however, i can view them from my camera. upon usb connection, the files that are visible only account...
Its possible that the format pic isn't compatible with the programs installed in the laptop, or anyone program (image) is settitngs to open this format pic; check it and tell us news.
If you are deleted the images, could try recovery with this Sony software: SonyPhotoRecovery
Hope this helps (remember to arte and comment this).
Dec 15, 2010 | Sony Cyber-shot® DSC-H20 Digital Camera
I accidentally deleted my sound device kindly help me
Since the driver was already installed, you just need to do the following:
Step1 : Open Control Panel from Start/Settings/Control Panel
Step2 : Open 'Device Manager'
Setp3: Select "Scan for hardware changes" from under the Action Tab.
This should fix your sound device
Mar 09, 2010 | NEC Versa VX Notebook
Hd 480 problem with godfather 2
Ok what that means basically is that your video card cannot handle the games graphics so you need to go out and buy a new one. I would recommend an ATI RADEON video card.
Apr 06, 2009 | Computers & Internet
Drivers for satellite L310
i need drivers for my satellite L310, PLS HELP ME CNF7051 ETHERNET CONTROLLER MASS STORAGE CONTROLLER MODEM DEVICE ON HIGH DEFINITION AUDIO BUS PCI DEVICE SM BUS CONTROLLER VIDEO CONTOLLER VIDEO CONTROLLER(VGA) UNKNOWN DEVICE
Feb 05, 2009 | Toshiba Satellite Pro L300 Notebook
Internet connection
if you bought the computer new and got a recovery disk it can reinstall drivers from recovery disk if not ur best option would be to get a recovery disk for ur type of windows
Oct 05, 2008 | Acer TravelMate 3260-4542 Notebook
I need to have a driver to detect my ECS GAYN20500595 to connect to the internet. What should i do?
go to start/settings/control panel/
when panel is open go to system/device drivers check modem does not have yellow mark on it.
If it does you will need to identify type and model of modem use friend to go on internet to find drivers
if it is clear go to modem in control panel right click/properties
when in modem panel go to diagnostics query modem
if it find modem then you need to set up internet connection from your provider
Jul 11, 2008 | ECS RS400-A (V1.0) Motherboard
Wireless connections
if you have win XP or equivalent, try using the default 56k modem driver by doing this...
...from DEVICE MANAGER...
double click modem and select the DRIVER tab, then select INSTALL FROM A LIST OR SPECIFIC LOCATION... then select DON'T SEARCH, I WILL CHOOSE THE DRIVER... then find the 56k default driver. It may not have all the bells and whistles, but it should get you started. Later, someday when the world is safer, you can find the driver specific to your modem.
ps...the above can be done on WIN 98, ME, 2000, NT, XP and up.
Mar 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Light are flashing
Can you tell me exactly how the lights are flashing. This flashing is a code that will tell me whats wrong witht he printer.
Thanks,
Brad Nelson
Mar 15, 2008 | HP PSC 1510 InkJet Printer
NeoWave PC Audio Graphic Equalizer External Sound System Logo
197 people viewed this question
Top NeoWave Computers & Internet Experts
David Payne
David Payne
Are you a NeoWave Computer and Internet Expert? Answer questions, earn points and help others
