Question about Philips 47PFL3603D LCD TV
My tv is cracked in top right corner also has lines running thru it.
    President:
  • 1,961 Answers
Replacing the screen of your tv will cost you a lot just like buying a new set of TV but to give you a tip,you can bring your tv to a repair shop and ask for a replacement of your screen they have that screen same as to you which are no repairable main boards so you can ask for the screen..hope this helps tnx..
please rate my help..
Posted on Jun 07, 2010
2 Suggested Answers
alpug
  • 1961 Answers
SOURCE: My kid threw a remote
clik here and follow the link.
check out the store they offer spare parts of LCD TV.If you wish to replace the monitor.however there is no problem or harm using your tv aside from obvious cracked you can use it anyway..
My cracked the corner of the tv and the tv turns on fine I want to know if it can be fix and it's worth fixing
If it works, you just need a used caseing, or just leave good enough alone. Peace
Dec 05, 2015 | Televison & Video
I have a line running thru my tv
vertical(up/down) or horizontal(left/right)? color/white? when you tap on the top of your tv does the line go back to a full screen? could be a makers defect.
Aug 22, 2011 | Samsung LN-S2651D 26 in. LCD Television
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
My kid threw a remote hit the top right corner and cracked it. Now I have lines going thru it. What can I do?
Jun 07, 2010 | Philips 47PFL3603D LCD TV
NO SOUND IN RECORDING THRU pci tV TUNNER
open your tv viewer and go to factory settings and go to video settings or something like that and turn your and set the mixer device from xxx output to xxx input and select the recording to line in
Jun 07, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Broken flat screen tv
If you have not yet fixed this and haven't trashed the set I may have a solution.
I have a 50HP66 that has a good screen but bad sustain boards.
I will buy the boards from you...Easy to remove. Then you can use that money to buy a new TV.
Fixing a cracked screen is not practical. IE. Replacing the whole screen.
These sets are made to be sent to the land fill when the warranty is up.
Maybe we should have our lawmakers force companies to have minimum warranties for large toxic products that end up in the trash. Then they might make them last more than a year.
Sep 17, 2008 | Televison & Video
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Red lines taking over my T,V
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 26, 2006 | Samsung HCM5525W 55" Rear Projection...
Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Nov 13, 2006 | Hitachi 50GX30B 50". Rear Projection...
Philips 47PFL3603D LCD TV Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
