Question about Bernina Activa 130
I have a Bernina Activia 125. The top stitch thread is leaving loops on the bottom of the stitching around the bobbin thread. The bobbin thread seems to be taught enough- but the top thread isn't staying taught at all. It's also inconsistantly loose. A couple inches will be taught- then the next couple will be loose. Thanks in advance.
    Brigadier General:
  • 3,513 Answers
After seeing your query I have come across a similar type of problem and a valuable solution by another respected expert on that. Please follow the link given bellow and go through the suggestion to have an in-depth knowledge regarding your problem…
http://www.fixya.com/support/t2864983-thread_looping_up_bottom
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 07, 2010
My Bernina Artista 185 has been looping the top thread on the underneath side. Is this a tension problem? No amount of adjustment seems to correct it. What can I do to correct the looping problem?
It is a tension problem. My advice is always to double check in the manual that you are threading correctly. With loops underneath, your tension is too loose, or the bobbin is not seated properly.
Nov 18, 2015 | Bernina Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Why won't my Bernina zig zag bobbin thread catch underneath; the top looks great.
have you tried changing the needle?
have you tried adjusting the top tension?
May 13, 2012 | Bernina Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
I own a Bernina 1260 and am having a problem adjusting my bottom thread (it has loops in it). I have tried adjusting the tension but I still cannot get a perfect bottom stitch.
Hello
You would pull out several long lengths of matching thread from my spool of thread and knot the threads together at one end (to hold them together). Grab the knotted end of threads with your left hand and place the threads(held taunt together) under the presserfoot of your sewing machine.
Select a narrow zigzag stitch that will zigzag over the threads, and holding both the knotted end(Left hand) and the other ends with right hand( holding tauntly), zigzag down the length of the threads.
You can use this for matching button loops, cording for belt loops, or whenever you need matching cord. The thickness of the cord will depend on how many strands of thread you want to use. You insert the loop of cord into the seam, so that when the garment is turned RIGHT SIDE OUT, the loop will be sticking out of the seam and you can put the button through the loop.
THANK YOU FOR VISITING FIXYA
Feb 02, 2011 | Bernina Sewing Machines
My top stitch is flat, but the bobbin is bunching and looping extra thread. cotton fabric, polyester thread
What looks like a bobbin problem is sometimes the threading of the top thread.
If you threaded the machine with the presser foot down, the tension is closed and the thread cannot enter as it should.
Improper seating of the thread into the tension results in loopy stitching as the thread is not being guided at the proper tension to create a satisfactory stitch.
Try re-threading the machine with the presser foot up.
Feb 18, 2010 | Bernina Virtuosa 160
Stitching too tight on top
I found a screw on the bobbin case (where you put the cotton for the underside stitching) which was very loose. I tightened it and that created more tension for the bottom thread which solved the problem.
Jan 02, 2009 | Bernina Activa 130
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Sewing Machines Logo
82 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
