Question about Nordic Track NordicTrack Treadmill, A2550
Cant close my nordic track a2050.... its stuck open...not very space friendly
  • 3 Answers
Does it close part-way? If so, it might be the same thing that happened to me. Make sure the incline is at zero. It will not close if the walkway is raised.
If that doesn't work, you might try disconnecting the incline motor screw (held in by a retaining pin and cotter pin), turning the screw one or two rotations and reconnecting it. I've had to do that in the past, but I'm sure it is not an approved solution.
Posted on Dec 21, 2010
Nordic track a2050 contol console lights but controls do notvwork
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair then check the following link.http://electro-medical.blogspot.com/
Aug 20, 2016 | Nordic Track Exercise & Fitness
Nordic track A2050 makes a clicking sound when first started up and is being used..it does go away after a min or so of use..seems to be getting worse but is hard to pinpoint. .bearing or motor issue?
lube the deck belt + rollers bearing see the video attached.
2) Test the bearing for main motor, and schedule maintenance for motor.
If the noise persist after you execute the maintenance motor+deck belt, TIME for replace the OLD board deck belt.
Feb 03, 2013 | Exercise & Fitness
Nordic track treadmill is stuck up in space saver position
see the video and proceed , use the common sense. God bless you
Oct 07, 2012 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack A2050 Treadmill...
NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack Elite zi...
Nordic Track treadmill, C1250. Can't install the storage bar, it seems to big.
tread has to be in 0 incline or close but you lift as far as you need to line up the ends of the latch bar installbolts done
Mar 13, 2011 | Nordic Track Exercise & Fitness
When i power my Nordic Trac A2050 on it powers up but when I press the speed button or incline button is beeps twice but does not reponse to the command
This sounds like a bad controller. If the machine is under warranty contact the warranty provider. The controller is not hard to replace if you are electrically inclined but it does require calibrating.
Jun 14, 2010 | Nordic Track NordicTrack Treadmill, A2550
Hello I have a Nordic Track A2050 treadmill and it has worked flawlessly till today, The unit was open (unfolded) and I wanted to close it because I nearly killed myself tripping over it, so I turned it on...
Hello there, The machine is attempting to do an incline calibration. Keep the unit lowered as you have it, reinstall the safety key, allow the unit to go all the way to the top and then all the way to the bottom. The machine will stop when at the bottom and the screen will go back to normal. The machine will not overtravel the incline motor and damage it. Just let the calibration finish the procedure and you will be fine.
Good Luck! Tim
FYI this will happen anytime the safety key is removed while the incline is moving on nordictrack brand machines.
Jan 11, 2010 | Nordic Track NordicTrack Treadmill, A2550
I just bought used Nordic Track Elite ski machine. It is stuck in the highest position. The owner said she never figured out how to lower it, but a friend walked up to it a did something and it lowered. I...
Stand on the back of it, facing the front of the skis. You might have to push the button that helps you raise it while you are staning on it. It is a very elegant ride down! Hope this helps.
Apr 17, 2009 | Nordic Track NordicTrack Elite zi...
Nordic Track NordicTrack Treadmill, A2550 Logo
191 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
