Question about Sony KP-46S25 TV
Betty\r\nI have a KP-46S25 that has the colors and
Betty I have a KP-46S25 that has the colors and images red and green divided on left side of the TV and the right side is ok. I would like to know how to solve this problem.
  • Sony Master
  • 1,212 Answers
You will need to have a TV tech rework or replace your convergence board. Thanks for asking!
Posted on Jun 07, 2010
The image is divide on three.red,blue,green. At first when on for the first 10 minutes it looked fine then the image diverged with the 3 colors. Now the image is divided in 3 colors all the time. What...
This most likely is convergence problem, see attached photo, do not pay for this help.
Set uses two convergence chips, they will need be replaced, less than 15 dollars for a pair.
If you are interested make a comment and I will assist you.
SD TECH
Aug 26, 2010 | Sony KP-61HS30 TV
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
My Sony KP-46S25 TV is blinking red light and is not turning on, please advise.
Please update this with the blink count. The standby light shouldbe blinking a repeated count with a pause. This will indicate the problem circuit and allow me to provide you with the probable defective part(s).
Thanks,
Dan
Jan 07, 2009 | Sony KP-46S25 TV
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
FOGGY COLOR
Sure, you can fine service menu with universal remote control. Just find properly code number for Sony tv.
Aug 11, 2008 | Sony KP-46S25 TV
Colores
El chassis de synch, no esta funcionando adecuadamente. Probablemente loose connections around.Si puedes quitar el tunner board y resoldarlo, hazlo; Pero la solucion esta en el chassis donde esta el tuner. Tambien lleva unos panel conectado verticalmenet, esos hacen mucho falsos. resoldalos. Por ahi si tienes dudas escribeme noetvs@embarqmail.com Hechale ganas!!!
Jul 29, 2008 | Sony KP-46S25 TV
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Mar 16, 2008 | Sony KP-46S25 TV
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
SONY KP-46S25
A "Gray Scale" adjustment may solve you problem. If one of the picture tubes is set too high it will cause these RETRACE lines. Then too a weak picture tube might cause this. If the horizontal lines are one color: red, green,or blue then whichever color that is shown would tell you which tube is set too high. Your set has 3 screen controls that control the brightness of each tube. One may need to be turned down a little. Stargazer
Mar 11, 2007 | Sony KP-46S25 TV
Tracking???
If everything else is fine-then the set needs to have the picture size adjusted. Sometimes this happens when there is a power spike. Otherwise you either have a voltage reduction on the curcit the set is plugged into, or your house. Or the power supply is gowing and not putting out enough juice to the set.
Dec 17, 2006 | Sony KP-46S25 TV
Televison & Video Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
