Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
How can i reset the software for my Ariston aml125
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
Can I connect my AML125 to hot water
Not advisable if it is a cold fill washer only, as you will then be rinsing in hot water, and this could cause shrinkage of clothing and other adverse effects..
O/k if it is hot and cold washer.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Control panel
generaly the only way to reset is by turning off the power to the oven at switch board for at least 30s. if this does not work check the back of the digital panal for any burn marks as it may have shorted when it fell back, also check any wiring connectors have not come off
Feb 18, 2008 | Ariston Technologies Ariston FO98P...
Washing Machines Logo
346 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
