Question about Motorola Mobility SLVR L7 Cellular Phone
Why does my phone say unable to charge - Motorola Mobility SLVR L7 Cellular Phone
"Unable to charge" message for W377 motorola (t-mobile)
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Mar 06, 2010 | Motorola Mobility W375 Cellular Phone
Plug up to charger and it says unable to charge
Remove battery, clean contacts between battery and phone, clean charging port, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Jan 18, 2010 | Motorola Mobility W385 Cellular Phone
Unable to charge my motorola ic502 message is unable to charge. this is second phone in 3 months with same message HELP !!
First take the battery out for a second. then put it back in and put the charger in the hole on the phone. Hold the start button and it should say phone charging. Glad I could Help!
Dec 27, 2009 | Motorola Mobility ic502 Cellular Phone
Unable to charge battery
Clean charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility RAZR V3
Battery issues
sound like you need a new battery
Aug 19, 2009 | Motorola Mobility RAZR V3
Unable to charge W270 Motorola with Moto V3 Charger.
Jul 18, 2009 | Motorola Cell Phones
Unable to charge
motherboard is weekplz go to the motorola service centre
May 12, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola k1 boost unlimited phone Unable to charge
u r facing a problem with charger circuit that lil circuit shud be replaced.
Dec 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
120 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
