I have a Ruud Model UAFD-036JAS Air Achiever 9 split system. Does the outside unit have a reset button?The breakers are on yet no action from fan. Please help.
    President:
  • 1,902 Answers
You have a blown or two blown fuses that will need to be replaced on the emergency shut off next to your condensor outside.
Posted on Jun 07, 2010
Outside Ruud Achiever series fan not running. Furnace and thermometer are working but air conditioner will not come on. Please help- I'm hot :)
Hello Hottie,
start by verifying that the outdoor A/C breaker is in the on position. If it is then there is a problem inside the unit (most likely a split capacitor failure) and you should have an HVAC company help you out because that is HIGH voltage.
Sep 01, 2013 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
I have a Ruud Model UAFD-036JAS Air Achiever 9 split system, when i try to turn on the a/c, nothing happens. I've replaced the contactor, run cap., put in a starter cap for the compressor, replaced...
If you push the contactor and it runs why replace all that stuff??? You have to figure out where your 24 volts stops on its way to the condenser contactor. wire red green and yellow together at tstat, this should bring on indoor fan and condenser. if idf runs but cu does not you have an issue either going outside or a pressure switch is tripped. if nothing runs you have no 24, either a blown fuse, tripped float or bad transformer.
Oct 03, 2017 | Ruud UBHC Air Conditioner
I came home house was hot went outside to check unit and fan wasn't running and smelled hot. My model # uacc-036jas. Is this a simple do it yourself fix or do I need to call service person
no fan was compressor running is there air coming out the vents ? do you know what a contactor is manuallly press it check the nreaker. 2 breakers one for airhandler one for condensor...
Sep 22, 2010 | Ruud Heating & Cooling
Ruud Achiever® Series 13 SEER the fan will not spin I have checked the breaker is there a reset button inside the unit?
There is a reset button on the outside of the unit near where the tubing and wiring comes into the unit. The button is encased with a red plastic cover. If the unit is making noise but the fan is not spinning, the problem may be related to the fan itself. First with the unit turned of, see if the fan spins freely. Then fire the unit up again to A/C and see if the fan is not moving. If not, carefully nudge the fan blade with screw drive in the direction it normally moves. if the fan engages, most likely the bushings are old and need to be replaced; RUUD may only sell the entire fan assembly.
Aug 14, 2010 | Air Tools & Compressors
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
My fan outside will not turn off. I have a Ruud Achiever 10 unit. I cleaned the coils on the unit outside and the filter for the furnace. The unit does cool.
Is the compressor also running or just the fan? If both are running, you've probably got a freon leak and the system isn't cooling properly so it runs continuously trying to reach the thermostat set-point.
If only the fan is stuck on, you've most likely got a stuck fan relay. Replacements are available at HVAC supply stores and most will sell to the public. Not a real difficult fix but BE SURE to pull the electical disconnect AND flip the breaker OFF before you attempt any repairs.
Jun 11, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
488 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
