Question about Skylink Group SkyLink GT-100 Garage One Garage Door Closer
Sectional Garage door won't open after wire coming off rollers - chain can't lift door. I had to take wire off to close as it had come unspun.
  • 504 Answers
I WOULD SUGGEST CALLING IN A PRO.
REWINDING THE SPRING (DANGEROUS) AND FINDING OUT WHAT WENT WRONG IN THE FIRST PLACE (HARD TO DETERMINE UNLESS YOU KNOW WHAT TO LOOK FOR).
SHOULD BE $ 60.00 TO $ 100.00
MONEY WELL SPENT
HOPE THIS HELPS
Posted on Jun 08, 2010
Testimonial: "Thanks, will take your advice"
How to fix a noisy panel lift garage door
Make certain that all rollers are tightened and greased not oiled. Grease entire working hinges and a light amount of oil on chain. CAUTION when door comes up over vehicle any runny oil will drop onto vehicle! Please turn off power while greasing. Best of luck. Please leave feedback.
Jul 03, 2016 | Building Materials
My garage roller door will open but not close what is wrong?
Assuming you mean your home sectional door, not roller door. A roller door is what commercial companies use on docks or storage buildings. Also assuming you mean that your motor unit (the opener) won't close it, not that you can't pull it down manually. With all of those assumptions, I would say either your sensors are misaligned or blocked, or your force needs adjusting, or your springs need adjusting. If you give more details on your questions, you are likely to get more specific responses.
Feb 19, 2015 | Building Materials
My Lift Master garage door will not close. It makes the closing noise but the door does not slide down. Whcan I talk to to fix this?
Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
Jul 06, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
My Sears 3/4 HP garage door opener opens the door about 1', then will not go past this point. It will close it as well. I have taken the door off the chain and the chain will run without the door...
1. disconnect the door from the chain. 2. inspect the door again, try oiling the rollers and joints. It is the chain that lifts the door. Try manually lifting the door. If it still does not lift open, it is the door and not the Opener unit. 3. Although you don't see kinks, look for any obstructions eg. the track. 4. Make sure the track has not lossened out at any point. 5 If you can lift the door,. connect with the chain. Goog luck. Basically I think it is the door mechanism that has some how misalligned.
Jul 05, 2014 | Sears Craftsman LiftMaster Chamberlain...
Lift master cablesi removed the cables and doors sectional doors to fix .how do i set the tension. and the roller brackets is there a diagram to tell how to install,there a two holes and i can't...
Please do not attempt to set the tension your self. Call a garage door service Co. Broken arms and fingers result. It is not worth the attempt. Those tension spring do all the lifting of the door and have to much torque to mess with.
Jul 21, 2011 | liftmaster Garage Door 1/2 Hp
Garage door opened fine but now when I try to close it, all I hear is a buzzing sound for 3 sec., light comes on but door won't go down.
Your trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to relieve the strain on the chain and then run the opener until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door squeak when closing
I had a similar problem and tried simlar fixes. Spraying the chain, the rollers, the track with silicon based lubricant did not good for my problem. My wife then listened carefully from where the squeak was coming. It was coming from the hinged in the actual door, the hinge like parts that allow the door to roll up. After we sprayed all of them, the sound just went back to the normal electrical / mechanical sound of the door opening and closing. I am sure our neighbors are happy too after 6 months of (very) early openings. Hope this helps.
Mar 21, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Skylink Group SkyLink GT-100 Garage One Garage Door Closer Logo
117 people viewed this question
Top Skylink Group Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Skylink Group Hardware and Accessory Expert? Answer questions, earn points and help others
