Question about Hayward 250kbtu Ng Pool Heater - Inground
H200 heater wont Light
Hayward H200 milivolt heater only lights when jumping the TH terminals on gas valve. Jumping the rest of the parts as repair guide states will not light the heater. Before following the guide I was usually able the get the heater lit by reseating all clip connections on front control parts and tapping on componants. The heater will ALWAYS light when jumping the TH terminals.
I have the same heater and have been struggling with it since we purchased our house 6 years ago. I am very familiar with the "tapping" method and just this year learned that I could jump the TH connections to consistently get it to light. Finally that too became unreliable as the heater would shut off shortly after I jumped it. I used a voltmeter to test the millivoltage coming from the pilot generator (assembly) and found that it was only around 300mv, whereas supposedly 500mv is required to open the gas valve. Before investing $70-$100 on a replacement pilot assembly I decided to take it apart and see if it needed cleaning. There was a bit of buildup on the thermocouple that I removed with 150 grit sandpaper. I re-installed the pilot assembly, lit it, and retested the mv. I was disappointed to see that the millivoltage was still only around 300, but as I watched it began to rise until it eventually reached 500. I then turned the thermostat on and adjusted it until it was higher than the temp of water and the heater instantly turned on. So far so good....
Posted on Sep 13, 2010
Why won't my Hayward H Series H200 pool heater not lite, what is the most likely problem
there are a few things you can check. make sure you have a good fuel supply. make sure the pilot light is lit. (just because the pilot is on doesnt mean you have good fuel supply). the pilot may be out of adjustment from the burner rail. the igniting burner rail may be dirty or blocked
Aug 13, 2014 | Hayward H Series Pool & Spa Heater 200k...
Hayward H 300 series pool heater for an inground pool. Pilot light is lit. Filter is clean. If I jump the terminals the heater will go on. If not the heater will not start.
I have an H300 Millivolt Hayward heater. It will start and run for about 1 minute then shuts off along with the pilot going out. I've tried cleaning all the terminals and running all new wiring but same result. I've also jumped out the TH to TH terminals leaving the jumper in place and it still shuts down after 1 minute. Any idea what that could be ?
Apr 24, 2011 | Hayward H-series Electronic Gas Pool...
Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-Series 200k BTU Millivolt Heater - Natural Gas burners will not ignite. Jumping th terminals /burners will ignite
You didn't say what terminals you jumped, but I assume it's the flow switch, or it could be the thermostat. The flow switch is located on the piping inside the heater. This flow switch is very important because if you didn't have water flowing through the heater it would oveheat. These do go bad or sometimes just get stuck depending on what type they are. If it's the thermostat, mounted on the front pane you're jumping, then either it or it's expansion bulb is faulty. GOOD LUCK Who needs a heater in JULY?
Jul 03, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
If the (th) terminals means the thermostat terminals then you have a bad thermostat and it needs to be replaced.
Jul 03, 2010 | Heating & Cooling
Does anyone know if the igniter also works as a flame sensor on a hayward h200 pool heater its an electronic ignition heater without a pilot light
Yes it does. Flame rectification is carried back through the ignitor assembly ground. Be sure all the points of contact are rust free between the ignitor assembly and the chassis.
Aug 10, 2009 | Hayward H Series Pool & Spa Heater 200k...
Wont stay lit
flame sensor is probably dirty.remove and clean with fine steel wool.it is located near bottom of burner near ignitor
Aug 08, 2009 | Hayward H Series Pool & Spa Heater 200k...
I have a minimax 250 i can light the pilot but the main burner will not light. i jump the th to th/pp and the pilot goes out.
are you sure your jumping th and th/pp? the labeling on valve is a little deceptive.should use 1st and 3rd terminal on gas valve. if your using correct terminals try same thing with thermostat wires disconnected from gas valve. this will isolate valve from all controls and safties.if it fires valve is good and need to look in thermostat loop for problems. hope this helps
Jul 18, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
We got a hayward h200 seriers, don't know if it is propane or gas
The p in the model means propane and you should also see a sticker on the gas valve that also says propane on it.
Jul 18, 2009 | Hayward H Series Pool & Spa Heater 200k...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward 250kbtu Ng Pool Heater - Inground Logo
1,488 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
