Question about Maytag Ovens
I have a Maytag gas oven-MGR5775QDS, SER. 17348179EP. The oven will not fire up. I replaced the heat element/igniter about 2 years ago. The stove works. There is gas.The broiler works What do you think. Thank you
  • 2,973 Answers
It seems that the gas is not reaching the oven because of which it is not firing up. The igniter is fine as the stove works fine, the gas is there as the stove works. The only things common being the gas and igniter. hence it is the gas that is not reaching the oven. Please change the gas line to the oven. Unless there is a separate igniter for the oven, you would have known.
Posted on Jun 07, 2010
  • djweg67 Jun 08, 2010
    Shelia, the oven have a ceramic igniter/glow element that fires the gas for the oven. This is what I replaced about 2 years ago. I could see that the old one was burnt out. It is very facile.
  • Rinoo Kumari Jun 08, 2010
    In that case it may be the gas line that is blocked for some reason. Please clean the nozzle in the oven as that could have been blocked due to fumes from the cooking.
Oven will not ignite
Unplug the stove, then take the wires off the heating element. Using an ohm meter check for continuity across the two pins. If none replace element. If there is, then he contactor in the unit is probably bad.
May 24, 2014 | Maytag 30" Built-In Single Electric Wall...
Maytag oven will not turn on
ignition unit for the oven may need replacing
Oct 09, 2012 | Maytag Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Maytag Ovens
Oven not igniting
Very common problem, the ignitor or glow coil heats up but no gas comes out. For me for the last 12 years this repair has always been a weak ignitor. Call your parts store with the model number and check prices on the exact part and on any generic ignitors for this unit. Replace the ignitor and this should do the job. This can be a bad valve not letting the gas through, but again I have never seen that and I replace 4-6 ignitors a week. Good Luck, Appliance Specialists.
Dec 15, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Can I replace a broken heating element
74003019 for about 30 bucks anywhere Kimosabe. Easy fix. Just remove 2 screws. Kill the power to the stove for safety amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Maytag 30" Built-In Double Electric Wall...
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
115 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
