Question about Cuisinart DLC-10S Pro Classic Food Processor
Cuisinart classic food processor wont run, motor start issue?
Hi all, I have a Cuisinart classic food processor which I would love to get going.
It has been in storage for a while and since being packed away has stopped working. I am not a whiz with electronics but I can use a multimeter and can tear down rebuild most this. In sourcing the issue I have stripped the unit down to a point where I can test each component and here is what I have found:
- Power coming into the unit is a steady 127v (I am using a transformer as I live in New Zealand where we use 240v).
- Power going to the switch (when switched off)is also 127v.
- When the switch is triggered the power drops to zero at the switch.
-When the switch is triggered the power at the SIEMENS motor start (capacitor?) drops from 127v, going in to zero and whats coming out is 14v
-This same 14v is what is measured across the motor when the switch is depressed.
So I am guessing that the motor start unit is shot as this reads "150Vac" but is only kicking out 14v when the switch on and the motor states it needs 110V to run.
I can run other test with guidance and would also be interested to hear if I can test the motor itself by wiring it straight up to the 127v coming into the unit, or will this be to much for a 115v motor?
Thoughts?
  • potofgoldbal Jun 07, 2010
    nicarta has answered one of my questions but I would still like to hear from someone more familiar with the Cuisinart classic food processor as it has such simple internals with no PCB or chip that my issue should be rather simple for them to figure out.
  • 600 Answers
No, don't wire the motor staight to the motor, you will have it fried, the capacitor you are referring also acts as a regulating device to have a steady 150vac, if that's what you read on the cap. have you tested the line from the switch to the cap, is there voltage? if yes, go after the cap to motor, if the voltage drops or runs to zero, definitely your cap is defective, replace that, but do not connect the motor straight to 127 v, or your motor would be toast running for sometime, 5 to mins max.
Posted on Jun 07, 2010
  • 506 Answers
This motor look like an AC motor. If it is an 110V AC motor, the 127V is a little high for it. If it have + or - 10% Tolerance the the Voltage is not too bad. It should power it up. Try the motor directly IF IT IS AN AC MOTOR. Otherwise get a DC voltage and test the motor on a DC voltage. Check for shorts on the motor. Also check for shorts on the PCB if there is a PCB.
    Yes the motor is a 115v AC, 60Hz motor.
    The power that I am measuring coming into the unit from the power converter is 127v (even though it states on the converter that it should be 110v - 115v) could this be the issue as this is way above the 10% tolerance you mentioned?
  • Nicholas Enyika
    Nicholas Enyika Jun 07, 2010
    This is just one of the problems, but not the actual problem. It looks like the voltage is being grounded. What the high voltage will do is to make the motor run at high speed. If this problem persist I will suggest you replace the motor. Let me know if there is any Printed Circuit Board (PBC) attached.If there is no PCB replace the Motor.
I have a cuisinart pro classic food processor, and even though bowl and top are locked in place, it will not start.
On the processor look at the bowl and lid and see where they are supposed to engage the motor. If this is broken then that is the problem, find something to push on where the part of the the bowl and lid assembly would push, if it comes on then you have figured out the problem.
Apr 17, 2010 | Cuisinart DLC-10S Pro Classic Food...
I have a very old cuisinart food processor. It stopped after I tried to make a dough in the mixer
If it is old enough you may have burnt up the motor. I don't know that the older FP's are designed for mixing dough.
Jan 23, 2010 | Cuisinart DLC-10S Pro Classic Food...
I put all parts on just do a simple and it won't turn on.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 21, 2009 | Cuisinart DLC-10S Pro Classic Food...
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Apr 08, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart mini prep processor blade not rotating
Replace work bowl and blade - see if it resolves the issue.
Oct 29, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
It just stopped working
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-10S Pro Classic Food Processor Logo
294 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
