Question about Remington Polesaw Wizard
WHAT TYPE OF OIL DOES IT USE I HAVE MODEL # 106890-02
    Brigadier General:
  • 4,088 Answers
Use regular bar/chain oil available from home centers, hardware stores, and saw dealers. Check for proper oiling by running the saw tip near some cardboard for a few moments--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Posted on Jun 12, 2010
How much oil and type of oil for my craftsman 42" mower
Oil capacity and type depends on engine size, manufacturer of the engine for the mower and whether it has an oil filter too. There should be a label stating model number near the battery that is under the seat, or it may have information for oil volume inside mower "hood". If you get the model number, it's possible to download a file for the manual at no cost.
Nov 01, 2017 | Craftsman Garden
What type of oil goes in the crank case in a Scotts model 6070S, rear tine tiller?
normal engine oil in the engine sump
gear oil 80 oep in the gear box
Jul 21, 2016 | Garden
Craftsman 5hp electric model 19551, type oil used and amount?
if you go to you tube Craftsman 3 gallon air pump oil change ,it tells you the brand of oil and shows the amount needed . hope this helps .
Dec 22, 2015 | Craftsman Air Tools & Compressors
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
What type of oil do you use for 21" rear discharge
The type of oil would be SAE 30 or 10W / 30 Motor oil
Jun 26, 2011 | MTD LAWN MOWER PART # 603-04196 TUBE...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Manual for Skil Saw model 77 type 17
I have a Skilsaw model 77 type 16. I have the original owners manual and would be willing to fax you a copy.
The manual only lists a part number for the gear oil, it is No. 249. This is for a 5-3/8 oz tube of gear oil. I checked with my local hardware store which services this saw and they called a factory rep. They told the hardware store with shipping and handling it would cost about $17 for the oil! However they also said that a 90 weight gear oil is close enough to solve the problem.
Hope this helps.
Sep 22, 2008 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Remington Polesaw Wizard Logo
286 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
