Question about Dell E173FP 17" LCD Flat Panel Monitor
It will not turn on i have to wiggle the cord to get it to come on and i have bought 3 new cords for it. it still will not work
  • 11,361 Answers
Kirby cord has a short in it
cable overheated at bottom joint, blown wire internally, will have to replace cable. phone 0800 294 4692 for new cable 27.95
Jan 13, 2013 | Kirby Sentria 192006 Power Cord
Skilsaw wormdrive stops working but if I wiggle the cord at the handle it sometime starts and will run until I take my finger off the trigger. Now it won't start at all even after wiggling the co
Replace the cord. Cords get internal breaks by the handle or boot because that's where they have the most bending movement. The wires break inside where you can't see them. When you wiggle the cord the connection is remade, usually with a spark hot enough to hold them together for a short time. When the saw turns off and the cord moves again the weak point breaks again. You can test this by pluggin in the cord and checking for voltage where the cord attaches to the switch.
Jun 28, 2012 | Skil - Skilsaw 77 Saw Hook - / Bosch...
My ps3 turns on but is not showing anything on my tv screen
If you are using the red white yellow cords then wiggle the yesllo cord thats the picture cord were it comes though and if that dont work make sure all the cords and in tite
May 29, 2010 | Sony Playstation 3 (PS3) Console
Bought a new power cord because I had to keep moving cord around to get battery to charge, move and would lose charge received new power cord and still have to move cord around to keep getting a charge...
First thing you need to do is STOP trying to wiggle the cord to make it work. You could damage the motherboard.
The power jack needs to be replaced. It's a pretty standard repair. You can try finding a local laptop tech from Craigslist or visit your local shop.
This type of repair usually runs 70-100 out the door (depending on where you live)
I don't recommend you trying to fix it yourself.
Apr 03, 2010 | Dell Inspiron B130 Notebook
Won't turn on unless wiggle cord
Had the same problem and cord wiggling worked for a while then no lights anyway I tried. I opened up the handle, and the 3 screws below the handle, to disassemble that part and looked into the little circuit board. The little on/off switch worked directly from the cb so just re-seated everything and Wiola! it works now. Seems like the little silver on/off button at the top loses contact with the actual switch inside and in my case re-seating restored that contact.
Hope this helps..
Feb 11, 2010 | DeLonghi WR25 Retro Belgian Waffle Maker
My monitor is starting to go black randomly. I
1. are your drivers new?
2. possible from video card
3. try not to wiggle cords :)) it's not from there
4. try testing the monitor on other pc's/video board
5. if it work on other pc/video board then try updating your driver or refresh rate to low
Jan 01, 2010 | Computers & Internet
We have a 47? LG Scarlet just over a tear old. In
Sorry to hear that. This indicates that the Input ports could be damaged. Pulling on the cords or having no 'strain relief' could cause this.
Check for any similar problems using the YUV or Video Inputs.
Cheers
Dec 29, 2009 | LG Televison & Video
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 | Garden
Laptop Not Getting Power
There could be a number of resons for this. Some thoughts:
1) Was your laptop working fine before you bought this new adapter? Eg. did it work with the previous one.
2) Are you positive that it is compatible? You should check all the power ratings against the old adapter (voltage output, current output).
3) Make sure the connector that plugs into the back of the laptop is a perfect fit. Connectors have a + and -. The outside metal ring may fit, but the inside 'pin' may be too small and not making contact with the receving part of the laptop.
4) Make sure that the connector inside the laptop has not broken. Easy way is to get a pencil with eraser and stick it in there and wiggle it around. If it moves sustantially, you may have some connector pins that have become unsoldered. If so, you need to get this fixed.
Apr 16, 2009 | Dell Inspiron 6400 Notebook
Just bought a new wired mic and it cuts in and out right were you plug the cord in to the mic if you wiggle it the mic will cut in and out. mic or cord?
please apply a lubricant contact cleaner from radio shack near you-in the place where you plug the cord and then put your plug in-out many times(because you said that your mic is new)
Jul 18, 2008 | Audio Players & Recorders
Dell E173FP 17" LCD Flat Panel Monitor Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
