I don't know what the switch located under the paper egress chute is foron the cannon pixma iP 2200 printer
  • 88 Answers
That switch is intended for paper thickness. When you use thick or thin paper types, toggle the switch.
Posted on Apr 10, 2008
IP pixma 3300 feeds paper in crookedly
Check your rollers. Located right where the paper goes in. These can often wear from use or become damaged if something hits it.
If one or more of these have some form of failure then this could be your cause.
Replacement parts and/or service (if under warranty) should be available from the manufacturer. Your printer on Cannons Site. <--- click Look for Service & Support. You may have to put in a ticket. Alternatively They have a support number 1-800-652-2666.
Jun 09, 2011 | Computers & Internet
My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Canon PIXMA iP1600 Printer
My IP 5000 Cannon printer says I have a paper jam but
Under the circumstances go to control and click on printer. Clear all the printing jobs. Switch off the printer and the computer. Wait for sometime and restart the computer and the printer. This should clear your problem.
Dec 20, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Cannon ip 1800 printer
hi, your paper feeder might be jammed, try seeing if your little wheels turn properly (where the paper is fed) let me know..
Sep 10, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
Installed printer will not print
I found a vista driver for a Pixma ip 2600 and downloaded it. My printer now works but the black ink doesn't. Don't know if it's a driver issue or otherwise. It might be worth a try for you. There are no available vista drivers for the ip3000.
Aug 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Lost installation disk for canon pixma iP 1500 inkjet printer
http://driverscollection.com/?file_id=26383 heres the driver
goto to printer setup in control panel add your printer by name or software this will get you back to what you want
May 14, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
113 people viewed this question
jasbo
jasbo
