Question about IBM ThinkPad T42 Notebook
No internet connection
The wireless card shows connected and the bridge shows OK but no connection to the internet. Also no connection when in the wired mode. Even with a external PCI card for wired, no internet. It all shows to be working but it doesn't.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 46 Answers
U should make setting
Posted on Jun 08, 2010
How to setup my xbox to my pc
You will need a network cable (cat5) if you have wirless you will have network card at the back of the pc spare, if you dont you will need a network expansion card, plug the cable into the xbox network socket, it looks a bit like a phone socket, and plug the other end into the pc.
The best windows for doing this is windows vista if you are using wirless internet because it allows you to bridge a wireless and cable connection together, windows xp will not allow this.
Goto network connections, goto start and bring up the menu and click settings, then click network connections, you should have two or more connections, 1 wireless and 1 wired, which will be your xbox, you will need to bridge connections, to do the you will have to highlight the both connections by holding CTRL and left clicking on 1 and then the other, now right click on the highlighted connections, a drop down menu should appear, with a option to bridge connections, left click that and a bridge icon should appear in the window showing that the 2 connections are now bridged, you will now be able to use the computers internet access to enter xbox live. You may find that you will have a strict NAT set up on your router, to avoid this you will need to forward some ports, if you get this far post back i will try to run you through this process.
hope this helps and good luck.
Aug 14, 2010 | Microsoft Xbox 360 Console
Wireless doens't work on my 7535 - it connects to the router, but not to the internet - internet does work on the main computer
You have to do a few steps to check the problem : 1.Check if the wireless switch is on, on your laptop.
2. If it is on then check if the network adaptors are installed or not. You can check that by going into device manager ( start - run - devmgmt.msc). If it is not installed you will find a exclamation mark or simply go to your manufacturers website and update your wireless driver.
3.Then go to Start\Connect To\Show All Network Connections (or, if this doesn't show up on your computer, Start\Control Panel\Network And Internet Connections\Network Connections). For your wireless card, remove it from the bridge (right click on the wireless network and enable it if it is disabled and then if you have a option remove it from bridge click on that.)
4.Restart your wireless zero configration. Go to control panel/Administrative tools/Services, right-clicking on the "Wireless Zero Configuration", and telling it to stop. After it stops, right-click on it again, and tell it to start, and then wait a minute or so and see what happens.
then try to connect and see if you can for this go to the network and sharing center search for all the wireless networks and try to connect. I think this should do it for you. If not reply with the message or error you get.
May 30, 2010 | Acer Aspire One PC Notebook
SPEEDSTREAM 4200 MODEM CONNECTED TO WRT54G ROUTER WIRELESS DONT
turn on the wireless option in the router...
plug your computer into the router type in
192.168.1.1
username: admin
Password: public
go to wireless tab
turn it on
END!
P.S.
Also you have to be in range!
Sep 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Connect itouch to internet
From what it sounds like, you are working in a Windows environment. What you are trying to do is bridge your wireless ad-hoc network with your wired network connection. Windows does not support this method of connection even though they have the option for "allow other network users to connect through this computer's internet connection". That would only work if you had two ethernet cards in your system, and that option bridges one ethernet port with the other. It doesn't support bridging to your wireless adapter.
Most laptop wireless cards do not support an "infrastructure" mode, which would turn your notebook into a mobile router. Instead they create an ad-hoc network completely separate from your wired network. There are some commercial pieces of software that can bridge the two, though I've never been able to make them work.
The easiest route would be to go to Target or a local electronic store and pick up a wireless router. You would take the ethernet connection from your laptop and attach it to the router. Then your laptop and iPod would both connect to the internet through the router.
Mar 29, 2009 | Apple iPod touch Second Gen (8 GB,...
How to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
Xbox live on this laptop
I assume you have a crossover ethernet cable.
put the my network places on your desktop.
right click on desktop/properties/desktop/customize desktop/tic
then on the network places icon on desktop right click/properties
right click on wireless and bridge devices
they are now sharing the same ip
be sure and remove /delete bridge when not sharing as the ip will stick forever likely.
that should do it if you need more info /open my computer and hit help and search for internet connection sharing as the firewall may need to be configured.
Jan 30, 2008 | Sony VAIO PCG-K35 Notebook
When i hook up the router i have connection at the computer side but
There is the possibility that there are too many users of the same wireless channel in your area or that your wireless phone base station is too close to the router and is interfering. Move the wireless phone if necessary. Then in the router there are configurable channels for the radio communication channels 1, 6 or 11 are preferred. If you see other routers in the area and it shows the channels they are using choose a channel probably 1 or 11 that they are not using. If the first try does not work try the other.
Jan 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
IBM ThinkPad T42 Notebook Logo
112 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
