Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Bell rings when starting the cycle it runs for about 5-10 mins then the bell rings and stops it looks like pe or 6e on the planel flashing but it still happens on the other cycles what could it be can you help
  • 489 Answers
You have either a water fill or water temperature problem.  Not sure because you couldn't be specific on the error problem.  You will need to call a qualified LG technician to diagnose this properly.
Posted on Jun 08, 2008
When you are driving a ring bell sound stays on
buckle your seat belt and make sure the passenger does too and see if it stops, make sure your directional is not on. when that bell rings something will be flashing letting you know what the problem is, look around for it.
Apr 04, 2014 | 1999 Chevrolet Silverado 1500
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Bell rings in Maytag Dryer
Many newer models have a wrinkle guard setting. They will buzz or ring or chirp with some sound to let you know to remove the clothes before the wrinkles can set in. Usually for 5 min or so near the end of the cycle.
Eric
Jun 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The car won't start turn over
It looks like antithieft system fault.
Jun 25, 2008 | 1992 Chevrolet Corvette
PE Problem
I don't know of PE as a error for the dishwasher, however stranger things have happened.
Lg has had problems with older units prior to mar 07. They have had wires breaking in the door. If you turn off the power and remove the panel. Look for broken wires and or wires stuck in the insulation. Check for continuity as sometimes it can be an internal break. Fix this and you should be good. Oh put some insulation between before closing it up .
Sgt 48
Apr 14, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
208 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
