Question about Kenmore Elite HE4 Electric Dryer
Dryer wont stop with stop button...still all lit up and jumps back and forth from 20 to 30 min
  • 78 Answers
THIS SOUNDS LIKE IT IS THE SWITH ITSELF, BUT FIRST COMPLETELY UNPLUG THE DRYER, CGECK THE RECEPTACLE FOR THE RIGHT AMOUNT OF VOLTAGE, 110 ON EACH LEG, IF OK PLUG IT BACK IN THEN SEE WHAT IT DOES, IF THIS DOESNR WORK, I WOULD SAY YOU NEED TO REPLACE THE SWITCH THKS LARRY LET ME KNOW
Posted on Jun 07, 2010
My electric dry button wont keep it on. if I hold it it runs. but the min I take my figure off the button it stops working. the model is an elite
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 04, 2011 | Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
heatman101
Mar 19, 2011 | Kenmore Dryers
Maytag bravos dryer wont start when button is pushed. all lights are lit except timer
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Machine wont restart after inadvertantly hitting the stop button instead of the pause button
I believe the final solution was to unplug the machine for several minutes. When it was plugged in again I hit one of the wash cycle buttons and after a minute or so the button indicating that the door was closed properly lit up and then the machine resumed it's cycle.
Aug 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tumble dryer starts then stops after 5 mins and wont restart
the thermostat near the element is your high-limit shut off fuse. look for other and change it, it would be your cycling thermostats. Your dryer is not cycling and the one you changed is doing exactly what it is suppose to do, saving you a fire. basically your dryer is overheating.
Apr 09, 2009 | Dryers
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
