Goodman model capf3636b6ba the unit doesn't even cool down my house today outside was 85 inside 77. the fan blows, but I think it blew harder before. I have noticed during winter it stayed on longer to get heat out and now it stays on longer, sometimes I turn the thermostat up because it has been running over an hour. what can I check? I will first open it up and attempt to clean it from dust. after that what can I do?
  • themedskers Jun 07, 2010
    thanks I'll do it
    Genius:
  • 1,040 Answers
Dear Themedskers,
Yours AC needs servicing
Posted on Jun 07, 2010
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
I had my a/c charged today because it has not been cooling the house down. It took less than a pound, but it still blows worm air. Fan and compressor all running. I cleaned outside unit, filters, replaced...
It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Jul 17, 2010 | Goodman CKL36AR36 Air Conditioner
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Heat pump not cooling
You may have a bad running capacitor on the outdoor unit. It is a round or oval can with three sets of prongs on it. Over time they can either become weak or swell due to an overload.
Aug 10, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
