Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
Enamel is peeling on the bottom of the oven at the back join the oven is only 4 years old and is emmaculate the oven is a model astro double B1602MDE1.5 is there a known problem with these ovens?
SOURCE: Oven wont work after cleaning
I have a single wall oven by fisher paykel I have had the same problem with it not working after the last self cleaning mode.
no fault codes show and the fan and light comes on and blows out cold air. I have reset the power and still it wont heat. broiler is out too. I called the store where purchased and was told they will order a part and come out. This must be an ongoing problem as they did not need to come out and trouble shoot .
I will have to barbeque for a while !
Posted on Oct 19, 2007
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
heatman101
  • 43501 Answers
SOURCE: Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 18, 2010
Oven enamel
your wiring is switched up. its a 220v check wiring diagram on the oven. make sure the neutral isn't switched around
May 28, 2017 | Ovens
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
F-4 error
This indicates an oven temperature sensor problem. Here is a link that should help http://appliancehelponline.com/oventempprobe.html
Jul 21, 2010 | Whirlpool RBD305PDS Electric Double Oven
Oven won't heat
hi, sounds like the heating element
Mar 07, 2010 | AEG U3100-4 Electric Double Oven
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Open Questions:
See all Fisher and Paykel AeroTech Double OD302 Electric Questions
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
130 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
