When I connect component 1 and 2 I get a no signal
  • pgaditt Jun 07, 2010
    S-Video is not an option in this case
No signal conecting wii with component to samsung p2370ms monitor
Remove the memory card from the wii , try again and it will work !
Oct 11, 2012 | Nintendo Wii Console
Tip
HOW TO CONNECT A DVD ON A STANDARD OR HDTV
TO START OFF WITH WE MUST UNDERSTAND SOME FUNDAMENTAL
BASICS .
1 We will examine together in a progressive way the different typs of cables available with a breaf description ,starting with the worst type of cable to the best
I would like to specify i will show 2 pictures 1 the connecter on a tv 2 the cable that goes with this connecter
No 1 Coaxial cable Coaxial cables have been around for a very long time until the end of the 70 s begine 80 s this was the only available cable .
Whats important to know about coaxiale cable is that audio and video signals pass all together this obligates a lot a filtration to seperate signals creating a lot of noise
No 2 composite or yellow , composite cable mainly appered in the beginning of the 80 s the main difference of composite compared to coaxial is that audio is seperated. The yellow cable is our video signal, composite (yellow ) must be matched with audio cables one red for right side one white for left side . advantages over coax better sound since audio is seperated from video , also better video because audio signals are absent from video signal so less filtration is necessary
10_31_2011_6_12_22_pm.jpgNo 3 S-video . S-video appeared at the end of the 80 s beginning 90 s . like composite video the audio signal is seperated it also has to be matched with a red and white cables for audio . whats the main difference between composite (yellow) and S-video ? well if we keep this simple lets say that a video signal is composed of many signals . Our composite cable passes all of them in the same time , but are s-video cable seperats colour signals cromonance signals and puts a seperate ground for each ,gives superier video signal and s-video can support higher resolution 480i 10_31_2011_6_34_01_pm.jpg.No 4 component . Component cables apeared mid 90 s. again like composite and s-video audio is seperated component cables must also be matched with red and white for audio .Component cables come in a paire of three one blue one green and one red , the main advantage of component is we are seperating the video signal even more with component we are seperating the three primary colours red blue and green ,also component cables have higher resolution than composite or s-video up to 1080
No 5 DVI (Digital Video Interface) appeared latte 90 s beginning 2000 . DVI was a majeur amilioration and like composite -s-vide and component, audio was seperated ,audio cables had to be matched . The main advantage of DVI is its multipine connecter that permitted us to seperate even more prescisly our video signal . Like composite DVI supports high resolution 1080
No 6 and the last HDMI (High Definition Media Interface ) the cream of all
there are many advantages with HDMI 1 1080 p resolution 2 no audio cables necessary 3 multi pine connecter 4 communication protocols ( the ability for devices like a tv and a dvd to comminicat together ,making things more user freindly 10_31_2011_7_05_52_pm.jpg
on Oct 31, 2011 | Televison & Video
I have a 32" flatscreen
Different video signals use different connections ...and we are speaking ONLY the video(NOT including the audio connections)
  • Composite Video (typically colored Yellow) uses 1 RCA connection on your TV
  • Svideo (uses 1 svideo connector on your TV) a circular connector with 4 pins in it
  • Component Video (typically colored Red/Green/Blue) uses 3 RCA connections on your TV
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like: http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
Mar 10, 2011 | LG 32LG30 32 in. LCD HDTV
I want to connect my laptop to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT. Before, I had a cable VGA-HDMI,...
I want to connect my CPU to a LG 32ld310.. I have 1 cable VGA-VGA ( and the sound jack to Audio IN ). I got sound, but no image, no signal, even with AV or COMPONENT.
Before, I had a cable VGA-HDMI, also no signal ( analogical & diginal ).
If I buy a cable VGA ( for CPU ) and 3 jacks ( green, blue, white ) for Component IN; does-it work ??
I need some help.
Dec 23, 2010 | LG Televison & Video
How do i get a picture thru component 2 so i can get 1080i quality. i only get a picture thru component 1.
You would need to unplug the input cables in the TV and move them to component 2 on the back. Assuming your input is at 1080i in the first place (ie, the cable box or digital satelite signal is coming in at the proper resolution). One way to check is to connect an external DVD player to the component 1 input and see if the picture is higher quality than the signal from the Cable/Satelite. Not sure changing to component 2 is going to make a difference. Good luck and let me know what happens!
Nov 04, 2010 | Akai PDP5090 50 in. HDTV Plasma Television
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
No signal
Try this.
1. Take note of what input you are using to your television. AV1 or AV2 or Component 1 Component 2.
2. On the remote, toggle the input selection to corresponding input for your DVD.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
