Question about Super Tutor Trigonometry (ESDTRIG) for PC
What is the equivalent angle between 0 and 360 degree of an angle of rotatioin that measures 1385 degree?
  • 3,083 Answers
305 degrees
Posted on Jun 07, 2010
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
Their are three angle d first one is 128 degree, the second one is 37 degree, find x
I presume that x is the measure in degrees of the third angle. Use the fact the sum of the interior angle of a triangle is equal to 180 degrees.
x+128+37=180
x+165=180
x=180-165=15 degrees.
Sep 16, 2013 | Office Equipment & Supplies
If the angle of the light striking a substance is 32.0 degrees and the angle inside the substance is 15.0 degrees what is the index of refraction
Let i be the measure of the angle of incidence; let r be the measure of the angle of refraction. Both angles are measured from the normal to the surface at the incidence point. Let n_i be the index of the first medium where the incident ray lies. Let n_r be the index of refraction of the second medium.
The law of refraction states that n_i*sin(i)=n_r*sin(r)
Assuming that the first transparent medium is air, we have n_i=1. Solving for n_r we find
n_r=(n_i*sin(i))/sin(r)
For i_r=32 degrees, and r=15 degrees
n_r=sin(32)/sin(15)=2.0475
May 22, 2013 | Office Equipment & Supplies
Convert -525 degrees into radain pi form
Here is some help
180deg is equivalent to Pi radians
Take some angle. Its measure in degrees is say x_deg, Its measure expressed in radians is x_rad.
The fraction of 180 deg that the angle represents is equal to the fraction of PI that this angle represents.
Conclusion: the ratio x_deg/ 180 deg must be equal to the ratio of x_rad/PI
x_deg/180 deg=x_rad/PI
Isolate X-rad in the above equation. Some will tell you to cross multiply.
x_rad=(Pi/180)*x_deg
Application: x_deg=-525 in radians?
x_rad= (PI/180)*(-525)=-(525/180)*PI
Keep the value (525/180) as a fraction reduced to its simplest form. The result is 35/12
Sep 26, 2011 | Casio FX-115ES Scientific Calculator
What is the angle of the 15 gauge nails for this gun and what nails are compatable
You did not mention the brand or model of your gun, however, you can determine the angle needed by placing a straight edge in line with the path of the driver and measure the angle from this edge to rails.. If the straight edge to the rails measure 90 degrees or makes a right angle, you need "0 degree" nails, if it measures 80 degrees, you need "15 degree" etc. Most generic nials 15 gauge nails will work. No need to by branded nails unless your gun requires an unusual angle. Good luck.
Jul 31, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
How do you find an angle measure for the angles XYZ if it looks like it's 63 degrees?
Place you protractor over the angle to be measured. Make certain the centre line is aligned with the apes (point) of the angle and one arm (of the angle) is aligned with the protractor's bottom edge. You can now read off the size of the angle by noting the position of the other arm under the protractor's degree scale.
Mar 17, 2010 | Alvin & Company PROTRACTOR 6 INCH SOLID
I want to connect my jabra bluetooth to my kyocera wild card but don't know how. it says i need a passcode
nine times the degree measure of the one of two complementary angles equals six times the degree measure of the other. find the measure of the angle.
Dec 27, 2009 | Kyocera wild card Cellular Phone
What is a linear pair and vetical angle.
A linear pair of angles is formed when two lines intersect. Two angles are said to be linear if they are adjacent angles formed by two intersecting lines. The measure of a straight angle is 180 degrees, so a linear pair of angles must add up to 180 degrees.
A pair of angles is said to be vertical if the angles share the same vertex and are bounded by the same pair of lines but are opposite to each other. Such angles are congruent and thus have equal measure
Sep 15, 2009 | 2007 Geo Storm
Computers & Internet Logo
50 people viewed this question
Top Super Tutor Computers & Internet Experts
ali_zulfikar
ali_zulfikar
k24674
Are you a Super Tutor Computer and Internet Expert? Answer questions, earn points and help others
