Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
My ice o matic, ice0250fa3 was working great in my 2 car garage for 8 months,then without notice it stoped making ice. i noticed the fan would not stop runing.then it sounded like somthing was tring to come on ,for only a moment[it gave a hum then a clik]but no ice. i turned it off for a day .then turned it back on, it made ice 1 last time. then it repeated the same problem, i v called iceomatic there advice was bring it in .times r hard, need advice thankyou. nj
  • nsjackson709 Jun 10, 2010
    can you tell me how to test a starter relay on my ice o matic 0250fa3
    can you tell me how to test the starter relay on my ice o matic ice0250fa3
    Brigadier General:
  • 4,090 Answers
It sounds like the solenoid switch has collapsed. Sometimes the reset like you did will allow the starter to return for refire when plugged. But as time goes by the spring gets lazy and sticks. To take this all apart is somewhat of a nightmare. So I don't want to suggest a DIY and cause you more stress in hard times. Maybe another refrigertaion engineer would be happy to help out on site. have you tried that option? I am in Oz so I cannot recommend one for you that would be local. But try your pink pages and see if there is a local bloke that is willing to fix it cheapre.
Thanks for using FIXYA
Posted on Jun 10, 2010
    President:
  • 1,902 Answers
The hum click sound that you are hearing is your Compressor. Ice-O-Matic is well known for there compressors going bad. What they had done was put in compressors that were to small for the size and amount of ice that they were creating. Replacing the compressor on this unit with a service tech is roughly about 200 to 300 dollars depending on where you live. They can have you up and running within that day. My recommendation is to call a Refrigeration company and NOT a Heating and air Conditioning company.
Posted on Jun 07, 2010
  • nsjackson709 Jun 07, 2010
    a tec told me it could be a starter relay ,do you know how to test the relay.
    can you tell me how to test a starter relay on my ice o matic?
  • 6,927 Answers
I am not familiar with that one but check the intake,and coils,and clean them ,Make sure the fan for condenser is working also,if it will make ice for a while,it sounds like a heat problem with the condenser.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Jun 10, 2010
    Let me know what you find,and rate this if you would,and thank you.
Makes ice but water want stop running n to ice bin
If you look above / behind your ice bin you'll notice a plastic hose wich feeds water to your ice maker. It may be loose or cracked allowing water to drip to your ice bin.
Oct 17, 2016 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
Samsung RF266AEPN BUZZING NOISE and back Panel Iced
Sometimes they ice up because the defrost cycle does not work, check for a faulty fuse, in the circuit board.
Jun 04, 2017 | Samsung RF266AEPN
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Noticed temp gauge running a little higher than normal.cooling fans turn on and off very quickly. turned on ac and the fans run. trying to diagnose without getting taken to the cleaners from the...
Check your coolant levels. If the temperature isn't much higher than normal, you may be fine, or you may have a Coolant Temperature Sensor going bad, and reporting the incorrect temperature. Even though the thermostat was replaced 8 months ago, it is possible it is already going bad again. I believe this is more of a Coolant Temp. Sensor fault though. The cooling fans are On when the AC is on. With the AC off, the cooling fans come on when the engine reaches a certain temperature, and cut off once the temperature is back in range. The Coolant Temperature sensor shouldn't cost much, and is easy to replace. I would start with that, top it off with coolant, and then maybe change the thermostat.
Mar 14, 2011 | Chevrolet Impala Cars & Trucks
The fan in the freezer makes a high pitched whistle when it is on. Also, the ice maker seems to overfill which causes the cubes to stay all stuck together and are breaking the plastic thing that moves the...
Thi over filling ice maker is cause but the ice maker water valve laking water by when it is supposed to be closed. The only remedy for this is to change the water valve. The water valve is item 800 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131037&diagram_id=22223831#d22223831
close up view:
http://www.appliancepartspros.com/part_details.aspx?part_id=3192626
The high pitched wine from the evaporator fan can either be the fan bearing or ice build up. If your not noticing the freezer temps warm up I would suspect the fan bearings. If you notice things like soft ice cream then you may have an automatic defrost problem. To isolate the possibilty of an automatic defrosting problem and post procedure fan test perform the following manual defrosting steps:
1. Unit unplugged
2. Remove freezer contents
3. Place a fan blowing into the freezer compartment for 2 hours
(Messy - rags and mop required)
4. Wipe residual water in freezer compartment
5. Plug in unit
6. Reload freezer contents
Check for fan whine and normal temps in 4 hours.
If the fan is no longer whining you probably have an automatic defrosting problem. If it still whines you can try lubricating the fan motor bearings with "Zoom Spout" oiler (Any Appliance parts source carrys this for under $3.00) Do not use regular oil! It will cause the fan motor to sieze in about 1 month.
Worst case the evaporator fan motor would have to be changed:
Item 610 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131037&diagram_id=22223826#d22223826
^- Note there are 2 types of fan motor. One with thermistor and one without. Both are listed under item 610.
Replacement plastic parts for the ice maker can be found here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131037&diagram_id=22223828#d22223828
There are several internet sources for all of the parts above. Links are provided for reference.
Thanks for choosing FixYa.
Kelly
Sep 18, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Intermittent interior fan on blazer 2000.
blower control modular,,are u engaging while moving or stopped.
Dec 08, 2009 | 2000 Chevrolet Blazer
ICE MAKER STOPED WORKING
IS THE METAL ARM IN THE DOWN POSITION?
Mar 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Smoke coming from front end of 2005 Taurus
if you had an oil change and oil got into the frame the fan could be blowing that back on the engine and that is what could be causing this smoke also check out the drive belt
Jan 14, 2009 | 2005 Ford Taurus
Freezer coils get covered in ice about once a month
If the fan is running, replace the defrost thermostat!! Make sure the heater is working... see blog on testing the timer and heater!!
Good Luck!!
Aug 17, 2008 | Frigidaire FRT18G5A Top Freezer...
It's a Kenmore alright
Do you have any frost buld up in freezer compartment?if so sounds like a freezing issue.If no frost build up is your fan running in freezer part if not you may need evap fan or a manual defrost.Your fan may have ice stoping it from turning.If your fan is running you may need to pull off your start switch located on your compressor.Shake it around if you here noise like burnt parts in it you will need a start switch.And remmember never turn your fridge up full blast normal is good or you will freeze it up. Good luck:)
May 28, 2008 | Kenmore 60721 Refrigerator
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
563 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
mike cooper
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
