Question about Sport & Outdoor - Others
We have a NordicTrack EXP 1000X. We purchased it new, but did not use it very much. We started using it again and now at different times (ie, 15 min, 1 min etc) it will come to a complete stop. It almost throws you off. Once you step off it starts moving again until you put your weight back on it, where it will once again stop. There have been times where you can feel the speed fluctuate, but the digital numbers do not change. We really hope you can help!
  • 10,515 Answers
BELT LOSES POWER
(Bogs Down or is Sluggish)
This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time
with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections
instructions.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem.
DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD.
The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core
against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a
control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause,
replace the control.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 07, 2010
  • Peter Wood Jun 07, 2010
    Thank you for the info.
    The belt seems OK. Got about 2 1/2 steps after pulling the safety key.
    Motor sounded the same flat or inclined to max
    Walking belt could be lifted about 2" with no problem
    Drive belt rotated to about 90 degrees
    Used a 3/4 x3/4" stick on the flywheel at 10 MPH and slowed it to a stop. This indicates the need for new brushes, correct. Also noticed that the motor mounting is not properly lined up with the belt drive. So the motor is skewed instead of being in line with it. The mounts are part of the frame so there is no alignment adjustment. Could this cause the motor itself to wear prematurely? I can send a pic of the motor belt alignment, it is very obvious.
    Where can I get the motor serviced or new brushes?
    Thanks for your help
    Peter Wood
    Removed the brushes. They are about 3/4" long, which seems like there is plenty left. Could the misalignment have caused the bearings/bushings to wear?
    Peter Wood
Speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Dec 10, 2011 | Exercise & Fitness
I need a mannual for my nordictrack exp 10000 xI. Can you help?
Here is a list of many different versions of the NordicTrack Exp 1000XI. If you know your exact model number you can click on your version and view a parts list and purchase an owner's manual. If you just need to look at a diagram of all the parts many of the equipment pages have that available to view for free. Hope that helps.
Sep 12, 2011 | Nordic Track Nordictrack Exp 1000...
I have a Nordictrack exp 1000x and it won't turn on. Any ideas?
Right next to the power cord is a circuit breaker. Check it to be sure it has not tripped. If so, reset the breaker.
Check the outlet, be sure there is power.
If that checks out, remove the motor cover (unplug the machine from power first) and check the fuse on the controller board. Chances are if the fuse is blown, the controller might be defective. Replace the fuse and try the machine. If it blows again, the controller is defective..
Dec 17, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
My nordictrack exp 1000x keep shutting down after it runs for a while. then i have to restart it and it will run for a while and shutdown again.
You may have a belt and deck problem. Test by the following procedure:
without the power on stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
Jun 13, 2010 | Nordic Track Exercise & Fitness
Nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
  • For questions about parts, service, user's manuals or non-working products, please call our NordicTrack Customer Service Department at 1-877-993-7999.
  • For questions about parts, service, user's manuals or non-working products, if you purchased your equipment at Sears, please call our NordicTrack Sears Customer Service Department at 1-888-825-2588.
Apr 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
My 1000x treadmill will come to a stop, I can still hear the motor, but the belt stops. I can get off of it and it will start again, this is a continuous problem.
check mtr dr belt being loose-if tight, mtr demagnatized due to speed fluctuating on console,friction with walking belt/board
Jan 07, 2010 | NordicTrack Exercise & Fitness
Have a nordic track exp 1000x treadmill and the belt is slipping
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Sport & Outdoor - Others Logo
35 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
