Question about Tomtom GO 910 GPS Receiver
TomTom Go 910 intermittent charging on windscreen holder
My TomTom 910 appears to have a loose fitting to the windscreen holder as the green charge light keeps going on and off. On the back of the TomTom unit just behind the contact strip there is an empty hole with a screw thread. It appears that this should have an insert in it to make the fixation to the windscreen holder more rigid when it clips on. Can you supply what appears to be the missing part to go in the hole?
Colin_Dollery-1@gsk.com
  • Anonymous Dec 07, 2008
    Same issue..
    Charging goes on and off as it makes intermitant contact
    Looks like a design fault.
  • thetrain2 Jan 06, 2009
    Same Deal here...This sucks.
  • 4 Answers
They are **** it is a design fault and they know about it sell the bloody thing asap even if they fix it they are never right iv had 2 replaced.send it back demand a free repair then sell it
Posted on Feb 05, 2009
  • 868 Answers
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Posted on Jun 03, 2008
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
Have TomTom 910 Having Problems Charging it.
The 910 satnav/mounting interface is dreadful- it is the cause of half the problems on this site! You can order the battery on the net. Google VF5 or Samsung ICR18650-24. To replace, strip off rubber strips. You need a mini star screwdriver, carefully pull unit out of cover gently levering at the side. Carefully observe plastic carry through which acts as button on the front and base clip underneath- this must be reinserted correctly. It is a vital part of the structure- observe it carefully! Remove upper small PCB and large PCB after removing 2 electrical connectors. Battery located under PCB. Dispense with rubber mounting. Reassemble carefully battery holder (loosely until you have placed previous plastic carry through). Tighten battery holder to hold plastic strip which must be located over mounting bracket, carefully reinsert both electrical connectors (different sizes), reattach large PCB then small one, then screw back in cover. It is likely you will then be stuck on initial screen with unit not booting correctly. You must then do software resets (opened paperclip inserted into invisible hole next to connecting strip at back). It is likely that you will have to connect to Tom Tom HOME to do this. I failed here as the darn unit will not connect to my computer.
An awful piece of equipment- I have gone Garmin!
Mar 18, 2009 | Tomtom GO 910 GPS Receiver
What do you use to charge the tom tom 910 in the house
In the box you have a 'desktop' mount. Looks like the windscreen mount without the ******.
Also you will have got a mains power lead.
Plug the lead into the 'desktop mount' (Left hand side) of the stick up bit.
Plug in and put your 910 onto the mount. It will 'Click' into place
The green light will shine to show it's charging.
To release the unit from the mount PRESS in the button in the middle of the screen top rim and lift off.
Remember to turn of the power at the socket to stop wasting electricity
The usb part of the desktop mount goes into your pc so you can connect to TomTom home or just plain old 'back it up'
It is ok to have power switched on or off when connect to the pc, there is no need to unplug the jackplug.
Hope this helps
Feb 28, 2009 | Tomtom GO 910 GPS Receiver
TomTom910 not charging
This is a common problem with the 910. Try putting an obstacle in the way of the wire to keep it on. Better still is to not use the home dock at all. Just plug the home charger in to the windscreen mount (device connected of course!) and charge it that way. You get a better charge and it will stay on.
Nov 16, 2008 | Tomtom GO 910
My Tomtom 910 is having charging issues.
Hi Evan,
The rubber bungs often come out but it doesnt usually effect the charging although the rubber bung is there to help reduce vibration when used with a mount in a car. I have had many 910's here in the past with the bungs missing but never had any problem with them latching into the mount. I would think your problem is either some other plastic part is worn or broken. However , if you feel that the problem is the bung then I would go with your instinct but you might have to find something else to fit in the hole as parts are not readly available for TomToms unless you buy a whole unit thats faulty to use as parts / spares. Im'e sure something could be made to fit possibly part of an eraser or similar rubber part. You might also be able to use a small rubber cable grommet or similar.
As far as I know , it isnt possible to get a virus on to the TomTom as such but it is possible to get corrupted data on the hard drive ( or SD card with other models ) especially if you download things such as voices etc. I have had TomToms here were owner has downloaded comic voices and the files have caused very strange things to happen with the TomTom. I even had one where a voice file was making it look like the screen was damaged , so , your'e correct in thinking that way. In your case though , I doubt if the dowloaded voices have effected the charging , its more likely the poorly fitting mount thats casuing your problems.
If you manage to get the green light on ( this only shows power is going to the TomTom , it does NOT confirm charging ) then leave it for a few hourse before attempting to turn the TomTom on as that will ensure a resonable amount of charge especially if you battery is very flat.
Hope this helps . ( please rate the above reply if you think its helpful in any way )
Good Luck
Sep 20, 2008 | Tomtom GO 910
Tomtom 910 sat nav.
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Tomtom
stevi at the back of your tom tom where your windscreen dock goes there is a small rubber bumper if you look to the right and down you will see the reset button it is a small hole above the dock socket. sandy
Feb 21, 2008 | Tomtom GO 910
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
337 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
