Question about Sony Acid Pro 6 Professional Music Workstation Full Version for PC
Antares evo wont work in acid pro 6
I downloaded antares evo trial and i cant open it in acid pro 6.0
    Sergeant:
  • 269 Answers
Try this till i know the main issue
http://www.johnrofrano.com/acidtips.htm
mel
Posted on Jun 07, 2010
Photo shop download
You may download trial versions of Photoshop and other Adobe software from http://www.adobe.com/downloads.html?promoid=JZEFS
Nov 14, 2013 | Sonic Foundry ACID Pro 4.0 for PC
I searched for plugins and scanned my c drive now acid pro 7 wont open help plz
Its unusual for software to stop opening on a PC without some sort of error, Acid Pro relies on allot of different elements.
Start by simply re-starting the machine if you haven't already.
Windows provides a repair feature in the add/remove programs tool found under "tools" make sure you have all your work safely saved & backed up then run this repair tool.
The following forum has a collection of useful things to try:
http://www.gearslutz.com/board/geekslutz-forum/351072-sony-acid-wont-start.html
Otherwise you should re-install the software, it will be much quicker and easier than trouble shooting the issue assuming you have the software to hand. And will ensure that the software is complete, as otherwise you may end up with it crashing while in the middle of a project, which would be more than a little upsetting.
Hope this is of some help,
Please comment if you need further assistance.
Best of luck,
Tom.
Jun 25, 2011 | Sony ACID Pro 7 for PC
I have a windows 7 pc.i downloaded the autotune evo 6.I installed it on my pc...it installed correctly..but the problem is that there is no option to uninstall it...i tried really hard but i couldnt...
When an application/program is installed, Windows does more than create a new folder on the hard drive. It also writes data about the program to a 'registry', that keeps track of many system settings, including installed programs. Your best bet at fixing this problem would be as follows:
- Download Ccleaner from here: http://www.piriform.com/ccleaner/download/portable Extract the .zip file and run 'ccleaner.exe'. Navigate to the 'registry' tab, and click 'Scan for Issues'. A list of potential problems with the registry will be generated. One of the things this will look for is any registry entries that link to folders that do not exist (like the one you deleted). After the scan has finished, click "Fix selected issues..." If you are prompted to back up the registry, you may do so, but it is not necessary. Restart the computer and try to install AutoTune.
- If that did not work, open the control panel (Start -> Control Panel, or type 'control panel' in the start menu search box) and navigate to 'Add/Remove Programs'. After the list has populated, look for your AutoTune program in the list. Select it, and you will see an option for 'uninstall'. Try to uninstall it. If you get a message saying that the program cannot be found, and you are asked to remove it from the list, say 'yes'. Reboot and try to install AutoTune.
- If you still cannot install AutoTune, download and install Revo Uninstaller, found here: http://www.softpedia.com/progDownload/Revo-Uninstaller-Download-74235.html This will deeply scan your system for any programs that are installed or that have left remnants of themselves behind. Try to uninstall AutoTune from Revo Uninstaller, reboot, and try to install AutoTune.
Mar 21, 2011 | Antares AutoTune EFX Full Version for PC...
Blue screen of death when using autotune evo
Obviously, this program is causing a conflict with whatever OS you are using. Try updating your OS and install new service packs, or, if that fails, upgrade your OS altogether.
Mar 16, 2011 | Antares Auto-Tune Evo - Pitch Correction...
Hello, I've downloaded acid pro 7 trial version E, on windows 7, when it executes it starts to try to load all my dll files on my computer...weird any help would be appreciated jazzmeus
I have not used acid since version 6.0, but used to have the same problem.
You might want to go into the settings of acid and change the plug-ins folder to something else. Solution would be to create your own plug-ins folder somewhere on your pc, and point acid to that folder.
If you have it set to the C drive, or the program files folder, that is your problem. Acid is scanning your entire system for plug-ins, instead of just one folder. (plug-ins are also .dll files)
The same goes for the virtual instruments settings in acid.
You might also want to disable the media manager from running when acid starts, it seems to cause a lot of systems to hang. If yours does not, and you use the manager, strike the last idea.
Good luck.
Jul 09, 2010 | Sony ACID Pro 7 for PC
Why doesn't antares evo bundle vst show up in Emagic Logic?
because your dont have a proper program to run the software.
Jan 01, 2010 | Antares AVOX 2 Vocal Toolkit for PC, Mac
I downloaded antares autotune evo and it will not open.
thats because it is a plugin not a program. you need an audio recording tool such as SONY Acid, Fruity Loops, Sony Sound Forge or something similar. Antares is not a stand alone program, it requires another program to run, hence the name plug-in, because you "plug it in" to another program. Sony will allow you to download free trials of their software, but they have limited functionality.
Oct 02, 2009 | Antares Auto-Tune 5 Native Full Version...
Acid Pro 6.0 freezes when it is "scanning for cd devices"
In Acid Pro 6 Click Options, Preferences and under the General Tab Check Box That Says "Use SPTI For Direct CD Burning".
Problem Solved!!
Apr 21, 2009 | Sony Acid Pro 6 Professional Music...
Acid pro and vista (inspiron 1720)
Sony says the operating systems listed on the box -- the ones out at the time you bought the software -- are the only ones supported:
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_adp.php?p_faqid=2651&p_created=1165596321&p_sid=gFBkVDkj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjQsMjQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9dmlzdGE*&p_li=&p_topview=1
-That- said, some people apparently have gotten Acid 6 working.
You have Acid 5. It won't hurt to check and update some other things, whether you're able to run Acid or not. (And if your computer is strong enough, you may be able to run XP in a virtual machine, but that's a whole 'nother story.)
First, click your volume control -- likely in the bottom-right corner, or through Start: Control panels, and ensure your "line in" level is set high and the mute is not off. Yeah, you probably did this. Please quadruple check.
Try Start: Control Panels: System: Device Manager. See if you have any little warning signs or Xs next to any of your devices.
You can also look in the audio device section and see what your sound card is. (A Dell made one day may have completely different guts than a Dell of the same model made a few weeks earlier.) You can take that information and download a new driver from the company, which will have more updated drivers than Dell.
Last, make sure you've installed the latest updates to Acid 5. It won't hurt, and might make a difference. Doubt it, but it might. And if you go the virtual machine route, you may benefit there from the marginal improvements:
http://www.sonycreativesoftware.com/download/updates/acidfamily
Nov 03, 2008 | Sony ACID Pro 5 for PC
Sony Acid Pro 6 Professional Music Workstation Full Version for PC Logo
166 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
