Question about Samsung SD 616T Internal DVD Drive
My dvd drive is not installed in my computer ?
What if my dvd drive is not installed in my computer ?
  • 476 Answers
You have the model and make so you can download the drivers from the manufacturers website for free
or maybe you still have the disk the came with the drive
Posted on Jun 07, 2010
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
My computer not responding when dvd disc inserted
Again Install Windows and then install PowerDvD to fix this problem.
May 31, 2010 | LG SecurDisc 20x External Double-Layer DVD...
How do I Install my LG GCC-4320B
ok take this step to connect the cd 0r dvd drive
To install an external DVD drive:
  1. When purchasing a new drive be sure to understand the many formats available: DVD, DVD+R, DVD-R, DVD+/-R, DVD+/-RW are a few for example. More recent technologies include DVD-DL, HD DVD and Blu-Ray Disc. A decent DVD drive should be able to read and write both "+" and "-" technologies and also support recordable (R) and re-writable (RW) technology. Essentially look for a DVD+/-RW drive if you plan on recording DVD's, or just a plain DVD drive for reading DVD's (movies, games, etc). There are a variety of speeds from 2x-16x for a wide spectrum of users and needs; higher speeds will record faster.
  2. If you have a USB connection on your computer you can use an external drive. The advantage to an exterior drive is that you can use it on other computers as well.
  3. To install an external DVD, just follow the instructions provided with the drive.
To install an internal DVD drive:
  1. Look for a DVD with the letters RW on the box. This is so you can read disks and record them as well. Make sure the speed rating is 16X and that the DVD is dual layer so that it takes care of the latest technology.
  2. Read the instructions that come with the DVD. It may require you to load the provided CD software before installing the DVD player. Leave the disk in your CD ROM player for the rest of the procedure.
  3. Disconnect the power cord from the back of the computer (goes to the wall socket of your house.)
  4. Open the case of the computer.
  5. Locate the hard disk or CD drive. Most have two connections and can only be snapped in place one way. One connection is for data and one for power.
  6. Check to see if your computer mounts the DVD/CD ROM drives from the inside or if they are pushed through the front panel (you may have to remove the plastic panel on some models.)
  7. Carefully remove the plastic “knock-off?? cover on the outside of your computer. Make sure you do this only when you are ready to install the DVD drive.
  8. Slide the DVD drive into an empty compartment or bay. If it’s an older computer you can secure it with screws that come with the DVD drive. Many newer computers have spring clips to secure the drive in place.
  9. Connect the DVD drive to the data cable. The data cable is wide like a ribbon and is also called a ribbon cable and has a red stripe on one side. There are two or three connectors on the data cable. One is connected to the circuit board, one is connected to your CD drive or hard disk and one in the middle (optional third connector) is usually not connected to anything. Use the middle connector for the DVD drive. If your data cable only has two connectors replace it with the one that is generally included with the new drive.
  10. Hook the DVD to the power connector. This is a normal round looking cable. There are usually several power connectors in the computer.
  11. If you don’t have an available power connector, then you can buy a “Y?? connector to hook up to the existing power cable. Unhook the power connector and hook it to one side of the “Y?? and hook the DVD to the other side of the “Y??.
  12. Re-assemble the cover and plug the computer back in.
  13. When you run Windows up it should look for the drivers for the new DVD player and automatically locate and load them from the CD ROM that you left in the CD player from the first step.
thanks
ok bye...........................
Nov 18, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
Cant install program from DVD drive GWA-4164b
do you use orginal CD or DVD. if you saying yes. your CD/DVD drive is getting break down
May 27, 2009 | Acer (4432A-002) CD-RW Burner
I am not able to install it.The windows is recognising the LG player.
Hey,
Cd and dvd drives are installed automatically on windows when they are connected properly. if your drive is not installing then your computers windows has problems, I would insist that you use recovery cd's to restore the computer to original state or use the windows installation cd to install windows to the computer again.
Note that the cd / dvd drive may work outside of windows, so you may be able to install windows with the drive even though it doesn't work in windows. check bios if the drive is detected there or not.
heres some info on the bios, how to get there and how to use it.
http://www.youtube.com/watch?v=Tc1t3c5Yke8
you may need to change the boot order so that the cd starts before the hard drive.
May 05, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Nov 27, 2008 | Computers & Internet
Installing a new DVD drive
Step1::Ground yourself by first touching a metal object or wearing an anti-static wrist strap. This helps protect your computer's internal
components from damage due to static.
Step2::Shut down your computer and unplug it to protect yourself from electric shock.
Step3::Open your computer's case using the door on the side or follow the manufacturer's directions for your desktop.
Step4::Install the DVD ROM on its own IDE channel. Since a DVD ROM uses a good bit of memory, it should also be the master drive. Set your old
CD ROM or secondary DVD ROM drive to "slave" and set the new DVD rom drive to "master."
Step5::Slide the new DVD ROM in the free 5 1/4-inch bay and use clips or screw into place if necessary, then use the data cable that came with
the DVD drive to connect your new drive. Plug in the power cable as well.
Step6::Replace the cover on your computer, plug it back in and boot it up. If you have Windows XP, it should automatically detect and attempt
to install the new DVD ROM drive. If it doesn't, use the installation disk that came with your DVD ROM.
Nov 27, 2008 | Acer Computers & Internet
Hi....trying to install vista into my laptop "presario c700"
check the boot sequence of your computer it must be on first boot from cd/dvd, if it is ok then thre is some problem with the DVD disk or drive.
Nov 08, 2008 | Compaq Presario C700T Notebook
External DVD Drives
Sorry to dissappoint you , but this not a possiblity.What you can to instead is copy the content of the DVD into a USB flash drive , and plugin the flash drive to your 4600c and install it from there.
A normal DVD reader writer drive , retails for not more that 65$ , so you can buy one two, more over local computer stores also keep refurbished drives, that you can get a good deal on.
Thanks
Mandeep
May 02, 2008 | Dell DVD-ROM for Dimension (6t903)...
Dvd drive wont read dvd's
You state a problem here that is going to need a lot more info before a suggested fix could be provided. is this a new drive you added to your computer or a "factory installed" drive? If a new drive, did it come with "driver files" to be installed into Windows and did you install them? During installation, what questions were you asked and how did you answer them? By the way, my DVD drive shows up as a "CD Drive" in My Computer too, but it still reads & writes DVDs. Try right clicking on the drive in My Computer, click on "Properties" and then click on the "Hardware" tab. When the hardware screen opens, try clicking on "Troubleshoot" and follow the directions. This might work if you are in Windows XP.
Jun 08, 2007 | Samsung (SD-612) Internal DVD Drive
Samsung SD 616T Internal DVD Drive Logo
57 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
