Question about John Deere 42 in. EZ Trak Bagger
My la 125 john deere runs about 30 minutes then looses all fuel Ive changed fuel pump and filter and cleaned tank and pickup tube
    Problem Solver:
  • 9 Answers
Check the switch on the botom of the bowl of the carb
Posted on Jun 07, 2010
  • silentfox884 Sep 15, 2010
    Same thing happened to me...got to the point it wouldn't start. There is a switch in the bottom of the bowl as mentioned above. Just unscrew it and manually engage/disengage a few times to unstick...Mine seems to work fine now.
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Jan 03, 2017 | John Deere Garden
Have john deere lt190 after a few minutes running it shuts down. New fuel filter cleaned carburetor and gas tank changed oil. What else could it be??? Stumped
run it till it stops, have a spark plug ready to check for spark, if there is no spark, chances are the coil is bad
Sep 04, 2015 | John Deere Garden
John deere la 105 is not getting gas to carburetor. changed pump and blew out lines
Take line off fuel filter and see if you fuel. Check the outlet in the tank and fuel cap vent.
Oct 22, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 997 randomly stalls. After a few minutes it will restart and run for a few minutes then stall again.
Sounds like air is being introduced into the fuel between the fuel tank and the fuel pump.
Jul 02, 2012 | Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 42 in. EZ Trak Bagger  Logo
431 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
