Question about GE Profile PDS20SFSLSS Stainless Steel Bottom Freezer Refrigerator
We came home from a weekend away and the freezer was slightly ajar. Everything had defrosted. Additionally, the refrigerator was warm. We closed the freezer and turned the temperature control to the coldest setting on the fridge. Now, more than 12 hours later, a thermometer in the fridge still reads only about 55 degrees farenheit. There are vents below the crisper drawers, just above the freezer in the fridge. I think these are supposed to be blowing cold air. They are not. What's wrong with my fridge??
    Novelist:
  • 117 Answers
There is a good chance that your refrigerator has frozen up from the door being left open.
The best and easiest thing to do is to unplug the refrigerator and prop the doors open for 24 hours to melt any ice build-up that may have occurred and then restart the refrigerator.
If the refrigerator still fails to pull down to proper temp, then you will need to dig deeper to find the problem.
Posted on Jun 07, 2010
We left for the weekend and our freezer door was left ajar. Upon returning, we reset the temp., but the freezer never got below 17 and then it shut off again. Is it a complete loss?
It is possible that an excessive amount of moisture was introduced into the freezer compartment while the door was ajar. If there is excess frosting on the walls or around the door seal, defrost the unit and see if it cools better.
Jan 20, 2013 | Refrigerators
Freezer door left slightly ajar on my hotpoint refrigerator
HI LINDA.DEFROST ALL FIRST 24/48 HOURS AND TRY.GOOD LUCK.ALI
Jul 06, 2012 | Hotpoint Refrigerators
Came home from a road trip and our GE Profile refrigerator was and still is, making a horrible buzzing sound. the freezer door was slightly ajar and the freezer temperature was 43 degrees. It's slowly...
Unplug it now and defrost contact me after you get that done. Because the door was open the refrigerator possibly missed some defrost and the control board is confused. Let me know, Thanks Sea Breeze
Oct 14, 2009 | GE Refrigerators
Refrigerator freezes everything controls are set to lowest setting
your air damper is open,
or your door is not closing properly
if you door was even slightly ajar you would have frost as well
check you air damer it may be stuck open
Oct 02, 2009 | Amana ABB1927DE Bottom Freezer...
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Dec 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Nov 18, 2008 | Maytag Refrigerators
Warm Fridge side
Defrost the fridge freezer overnight. Restart unit. If it starts working you have either had a door ajar or a defrost problem. If it fails to cool down at all then you may still have a defrost problem or a evap fan motor faulty. Most likely outcome is that the unit will work once defrosted for approx three weeks after which the freezer will freeze back up. Most likely cause will be the defrost heaters. Any good tech should be able to help on second failure. Hope this helps.
Sep 05, 2007 | Whirlpool GS6NBEXRS Side by Side...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Freezer and refrigerator run but is not cold
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Aug 21, 2006 | Kenmore 50522 / 50524 Side by Side...
GE Profile PDS20SFSLSS Stainless Steel Bottom Freezer Refrigerator Logo
198 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
