Question about Canon PC-920 Black and White Copier
E2 20 error on Canon PC920 copier
Copier attempts to make a copy. Displays E2 20 error and turns off.
  • Canon Expert
  • 316 Answers
Fixing assembly low temperature
Posted on Jun 07, 2010
How do i fix c4 display by sharp sf-1025 copier?
It appears that the copier has a hardware error resolve it else repeated power-on will only damage it further
Jun 25, 2015 | Sharp Office Equipment & Supplies
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
Canon copier PC785 displays E0 and turns off
fuser unit is located near the printing
output
Sep 02, 2009 | Canon Office Equipment & Supplies
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
XC-830 copier Displays fault code H-3
Give this a try , if it continues you will have to replace the fuser.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy
Aug 07, 2008 | Xerox Office Equipment & Supplies
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
ERROR UF-
I can help you, but what kind of copier is it? What make and model?
Mar 02, 2008 | Office Equipment & Supplies
My copier powers on without errors but doesn't copy
hi im jules_09,turn it off first then turn it on for a 5 sec.try using a automatic voltage regulator
Oct 02, 2006 | Pitney Bowes C180 Copier
Canon PC-920 Black and White Copier Logo
316 people viewed this question
old marine
old marine
