Question about AO Smith Plumbing
My above ground pool pump (Hayward Pool Model SP1520) stops after running for about 14 to 20 seconds. It will restart right away but stops again
    Sergeant:
    Champion:
  • 426 Answers
Check flot
Posted on Nov 06, 2013
  • 250 Answers
SOURCE: My pool pump has a loud grinding sound
There is a number of things that could be causing the problem. The most likely thing is that a bearing on the motor is going out. The other possibility is that there's a foreign object stuck in the impeller. The best thing to do would be to DISCONNECT THE POWER and then remove one of the pipes connected to the pump. See if the impeller (the wheel with vanes on it) turns freely. If it doesn't turn freely and there's no foreign objects, then it's a bearing going bad. You should turn the pump off because it could damage itself further. Depending on your mechanical skill or availability of a local motor shop, it might be cheaper to get a new motor or whole new pump than it would be to repair it.
Posted on Jan 04, 2010
john224
  • 1378 Answers
SOURCE: My husband changed the sand in our Hayward Sand
Thank you for posting your question here on Fixya.com.
He broke the lateral assembly in the process and it will need to be replaced. You'll need to know the model number of the filter to get one. Then remove the sand, replace the assembly, fill the tank ~1/2 way with water, slowly add the sand back into the tank and replace the valve.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 06, 2010
  • 221 Answers
SOURCE: what in addition to a pool pump capacator is
If the capacitor was grounded for more than just an accidental touch, it could possibly short the start windings.
Posted on Jun 21, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: Pool Pump does not Prime.
CRAIG .. IF ITS A STA RITE PUMP DURA GLASS YA GET IT FIXED ! SHOULD COST ABOUT 75.00 SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY . ASK IF HE DOES FREE MOTOR TESTING
Posted on Jun 30, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: I have an AO Smith SQ1102 pool motor that stopped
no. it sounds like its too late for your motor , no need for a pool pump motor repair kit ,there is one on ebay . but it sounds like your motor is toast if it blowing the breaker... hey i could be wrong . look for a shop that has free pool pump motor testing .use your zip code in your search..
as far as using the bearings off them threw bolt motors. do what ya got to do, but you might find that the front bearing is a bigger bearing .. i charge 85.00 to rebuild a 2.. but you must catch them befor its too late 2hp new = big $$$
best of luck .. and if'n i was any help ? push on them thumbs up to vote ... thanks jay..oh PRIME THAT PUMP !
Posted on Jul 31, 2010
My bug worked great last season but this year I will find it stopped in the pool not moving, I will pick it up and push on the feet to get them running again and it will stop again, what do I need to
It may be that you have one of several possible problems that could be the reason for the symptom you are experiencing:
  • Low water flow thru circulation system
    • Dirty Filter
    • Baskets filled with debris
    • Clogged Pump Impeller
    • Clogged suction line between suction port and actual cleaner
    • Clogged/plugged cleaning unit itself
  • Worn gear assembly within the LadyBug
Jun 12, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
Switch is turned on but pump would not run. shaft turns by hand
It's junk made by Hayward. I've gone through two motors and am starting to hear the familiar noise of another motor about to fail.
Jul 05, 2012 | Hayward Pool Products Economy 1 Hp Above...
I have a leak in my above ground sand filter, model 140. the leak is around the drain. How can I fix it? It is a Hayward, high rate sand filter, GM series, model 140ab. Thank you
Usually in th bottom of the filter you have two parts. The first is a piece with a screen that threads into the plastic housing. The second is a Cap with a rubber washer inside. Make sure the rubber washer is there. Do not overtighten the drain into the houseing
Jul 24, 2010 | Hayward Pro Series 18" Above Ground Pool...
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Jul 03, 2009 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Hayward above ground pool pump will not start.
sounds like the windings in the motor are shot! but does it have a capacitor? if it does you could simply have a bad starting capacitor so don't let it hum for that will surely scar the windings
May 31, 2009 | Hayward Pool Products Economy 1 Hp Above...
Plumbing Logo
257 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
