Question about GE (PSS26MSRSS) Side by Side Refrigerator
Both refrigator and freeze not getting cold . just opened freezer door and the ice is melting .
    Guru:
  • 1,524 Answers
Freezer not freezing but still cold
you might have ice on the coil in the back of the freezer under the cover. move your food to a cooler. eat a lot of frozen food then unplug the freezer and leave the door open for a few days this will melt the ice hopefully with no effort on your part. then plug it back in and wait a few hours to see if it gets cold.
Sep 14, 2014 | Refrigerators
My refrigator isn't making ice, and hasn't in about 6 months?
It could be a couple of resons, I have the same problem. With my refrigator its the water tube that fills the tray freeze up. So I have to shut off the unit, leave the freezer door open for about 30 minutes or so. Then restart the unit.
Jan 31, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator cold control doesn't work; temperature stays at or below freezing. Freezer control OK.
check the damper door between the refrige and freezer compartments,its behind a plastic cover,if its iced up in the fully open condition it will allow too much cold air into the refrige,if this is the case defrost it with a hair dryer and recheck operation,otherwise the temp control in the refrige is bad
Mar 18, 2010 | Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
155 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
