Have a Vulcan V521I N/GAS /PAD and the touch pad
Have a Vulcan V521I N/GAS /PAD central heating and the touch pad isn't working.
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave touch pad work light doesn't work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
SOURCE: heating pad
There are no repairs done on Sunbeam heating pads. If it is less than a year old either take it back where you purchased it or contact Sunbeam.
Posted on Feb 24, 2008
  • 86 Answers
SOURCE: vulcan cx90 ducted heater
240 volt wiring required.
Posted on Mar 17, 2008
SOURCE: touch pad
Update - Turned the Circuit Breaker off to stove and turned back on. The second time I did this, it "fixed" the touchpad. Clock resumed flashing the time and all buttons work. Thank goodness no service call this time!
Posted on Jun 10, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Touch Pad mouse not working
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
Posted on Oct 10, 2008
F21
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer gives code F22. I replaced the door lock mechanism but it still will not start.
Hi, F-22 means that the CCU /touch pad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
Your model's tech sheet gives error codes and remedys.
Jun 17, 2011 | Kenmore Elite HE5t Washer
Error message F22
HI. This error occurs if the touch pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch pad/LED is responding.
3. Check wire harness connections to the touch pad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wirineing harness is ok, and connected properly)
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error f 21? what does it mean?
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/proceedure:
More Here
Jan 12, 2011 | Washing Machines
F21 keeps on flashing???????????????????????????
This error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22
This (F21 or FF22) error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
See the full list of codes at:
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code f 21
CCU/TOUCH-PAD/LED ASSEMBLY ERROR. this error occurs if the touch-pad/led assembly is not able to tranmit/receive data to/from the central control unit (CCU) 1 check the touch-pad/led assembly by selecting different cycles and changing the modifiers and options available to cinfrim the touch-pad/led is responding. 2.unplug washer or disconnect power. 3.check wire harness connections to the touch-pad/led assembly and central control unit (CCU) in the back of the washer there should be 3 or 4 t20 torque bits there star looking bits the screws are above the water vavle take those out then pull it towards u and the CCU is right there in the back on the top u cant miss it or its might be on the side good luck scott8326@hotmail.com
Feb 17, 2010 | Kenmore Elite 45986 Front Load Washer
Touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
F21
unit (CCU).
responding.
(CCU).
unit BRAND new id look into a wire off , 1year warr. id call them so as not to void any warr.
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Touch pad on
It is more than likely the touch pad that is faulty. I have installed many bonaires, and the only thing to go wrong at that age is the touch pad, or the problem is in the control box in the airconditioner.
The touch pad comes off quite easily by placing something flat behind the pannel and leavering it off gently. The touchpad has two pieces, the front, which you see, and the mounting bracket. The bracket is almost as big as the front pannel, so you only have approx 2-3mm of plastic edge to lever, so be careful not to hook onto the mounting bracket as well.
Once you have removed the front, you can then unplug the lead coming from the touch pad (be sure to turn the control box off in the airconditioner before removing this wire, there is a switch on the side of the control box (yes, you have to get on the roof, sorry)). Take the touch pad to your local retailer that sells Bonaire units and see if that is the problem.
Jan 11, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
