Question about Kenwood KM300 Chef Stand Mixer
I have broken the 15 tooth planetery nylon gear of this mixer. Can you supply it, & I assume I would need the spindle tool socket shaft which it clips to.
Kv25g0xbu
Back cover off, pedestal off, planetary off and then undo all the gearcase screws. Two wires need to be removed from the speed control plate too, 1x white, 1x black. You can then split the gearcase apart and change the gear. Planetary and nylon gear are both held on by pins that need to be punched out with correct size punches, both different.
Dec 22, 2013 | KitchenAid KSM50PR Professional Series...
My older model Hobart n50 mixer stopped working. The motor is running but three teeth on the fiber gear were broken off from the main gear in the transmission. While removing some of the grease, I found...
The best solution I can give you is to become a member at the Hobart Corp. website and use there schematics to find where the pin goes. It is free to use the parts catologues have a parts blowup.
Follow the link below:
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FsalesZ2Fredirect.aspx&reason=2&formdir=2
Thank you for using FixYa, I hope this helps.
Jan 19, 2011 | Hobart N50 Stand Mixer
I need to replace the rotatating column on my KitchenAid mixer.
Hi ALLENJUJU. To replace the agitator shaft will require a significant amount of extra effort, but will be well worth it in terms of gratification and reward for being able to successfully do it yourself. First, I’ll assume your mixer is no longer under warranty. Second, I’ll assume you have your Repair Parts manual on-hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: “Case Gearing And Planetary Unit” which shows you an exploded view of all the mechanical parts and assemblies for your mixer.
I highly recommend the following website that provides you step by step instructions with pictures (worth every bit of a 1000 words) to gain access to your planetary housing and agitator shaft. The mixer displayed is a different model (tilt-up) than yours, but the ‘insides’ are the same.
It would be helpful to have the following tools available as you begin to disassemble your mixer: a flat screw driver, a small Phillips screw driver or a punch drive, a pair of retaining clip/ring pliers, and a hammer.
You will need to remove the Planetary Drip Ring (Illus. No. 42) and Pin (Illus No. 25), which secures the Planetary Housing (Illus. No. 33) to the Center Vertical Shaft (Illus. No 19). (See pictures 6, 7 & 10, 11 from the link).
You’ll need the punch drive or small screw driver with a smaller diameter than the pin, a hammer, steady hands and plenty of patience. Rotate the planetary housing to expose the retaining pin with the vertical (center) shaft.
After removing the Planetary Housing, remove all the residual grease from the 18 tooth Agitator Shaft Pinion Gear (Illus. No. 47), which should expose a Retaining Clip (Illus. No. 61), which will need to be removed. With the Retaining clip removed, the pinion gear and Shim Washer (Illus No. 45) should easily slide off the top of the agitator shaft and you should be able to pull the agitator shaft down through the planetary housing bushing.
Take your new, replacement agitator shaft (be sure you’ve got the lower groove pin ordered, too, and insert through the bottom Planetary bushing. Replace the shim washer, 18 T Pinion Gear and Retaining Ring. Grease up the whole works with new grease, and reassemble the opposite of how you took it apart.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
I hope this helps - hslincoln, Burke, VA
If this solution has been helpful, please rate it, thanks! hslincoln
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
The problem's in a Kenwood Chef food mixer. Model is Chef A703C which I imagine will date back to the 1980's or 90's Problem # 1) The bearing on the top of motor is sloppy. It howls when operating the...
Try Ebay for parts, and the links below, they sell parts and service machines.
http://www.kenwoodchefusedmixersandspares.co.uk/
http://kenwoodchefrestore.co.uk/Service.htm
Mar 11, 2010 | Kenwood KM300 Chef Stand Mixer
My kitchen aid mixer is leaking oil or grease from the center shaft. When I opened the planetary there was grease in it. is there suppose to be grease there? is there a seal needed for the center shaft?
Hi TIOBEAN, by the symptoms you describe it appears the Center Shaft ‘O’-ring and quite likely the Transmission Gasket need to be replaced. You don’t mention how old your Artisan mixer is, but I assume it is out of warranty.
The internal gears of your mixer are factory packed with enough grease to last a 'lifetime'—whatever that means, and depending on the age of your mixer, where it was stored, degree and intensity of usage; these factors all contribute to the breakdown of the grease into its constituent parts (oil and suspenders), which have seeped beyond the gasket and ‘O’-ring, down the planetary (agitator shaft). Gravity can be very insidious. The residue coming from the agitator shaft is the gear lubricating grease oil that has come out of suspension.
So how bad is this oil leak problem and what can you do to fix it? First, if the amount of oil found leaking was small and if your mixer otherwise works normally with the missing oil you really don’t need to take your mixer apart to ‘fix’ it. The good news, though, is that you can take the mixer apart and 'fix' it, if you feel it is necessary.
It would be helpful to have the Part List manual as a reference. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Having the Parts List on hand will also be helpful as you will have to disassemble and reassemble your mixer to replace the ‘O’-ring and gasket.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, KSM150 and select the file KSM150PSWH0.pdf (773.44 KB) listed for your model that appears under Parts List (61), and save that file to your PC.
Turn to pages 6 & 7, titled:”Case, Gearing And Planetary Unit” and locate Illus. No. 28, Center Shaft & O-Ring; particularly Illus No. 15 & 16, Transmission Gasket and ‘O’-Ring respectively. I suspect these parts have failed and will need to be replaced. Now the real fun begins!
To get to the Vertical Shaft you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. After removing the Gearcase Motor Housing (mixer top) you will need to remove all the lubricating grease from the transmission housing and gears. This will allow you to remove Illus No. 11, 13, & 14, Bevel Pinion Center Gear, Pin (Vertical Center Shaft) and Groove Pin, respectively.
You should now be able to tap the Vertical Center Shaft (Illus. No. 12) down through the Lower Gearcase housing to access the ‘O’-ring.
Besides ordering a new ‘O’-ring (Illus. No. 16) and Transmission Gasket (Illus No. 15), you’ll also need to replace the grease you removed with new grease. Do not try to reuse any original grease as it may have ‘debris’ in it. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
With your mixer apart and the grease removed from the gears you can check them for any other unseemly wear and tear, too.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I've lost the spindle and can't find a replacement. help
The agitator is here.
http://www.wasserstrom.com/restaurant-supplies-equipment/SearchCtrlCmd?storeId=10051&langId=-1&searchType=Basic&filter=&sort_results=relevance&narrowSearchTermFilterArray=&newSearch=true&stdPageSize=20&currPgNum=&searchFilter=&errorViewName=SearchResultsView&search_field=Hamilton+Beach+%22Spindle%22
As far as I can find out the only thing available is the motor and shaft itself for a substantial cost.
http://www.etundra.com/Motor___Shaft-P7019.html#FitsManufacturers
Break out the yellow pages and contact your local restaurant supply.
They should be able to supply you with what your looking for or at least let you know where you can get one.
Jan 28, 2010 | Hamilton Beach DrinkMaster Classic...
Under a heavy load, the mixer began clunking once per revolution
Disassembly and inspection is the only way to verify what it is. It sounds like you are correct. I have bought parts very reasonably on line and repaired our K/A mixer. The better sites ( I think I used appliancerepair.com) have exploded diagrams. If you are tearing into yours, these are invaluable, and when you get to the broken part, you'll have a name for it.
Best regards, --W/D--
Aug 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Gear cap which attaches to the drive spindle falls off
there should be a lip on the shaft that hold this up. You insert the shaft from the bottom and a pin goes through the gear to hold it in place. Look at the IPB HERE.
May 25, 2008 | KitchenAid KP2671 Professional 6 Series...
Kenwood KM300 Chef Stand Mixer Logo
91 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
